94-302-vert
Both.
The engine supplies the power that spins everything, but the relationship between driveshaft and tire RPM (speed) are the rear gears.
To make the math easy:
When your tires are roating at say 500 RPM (call this 100 MPH) with 2:1 gears your driveshaft is rotating at 1000 rpm.
Change the gears to 4:1 and your driveshaft is now turning 2000 RPM at the same tire RPM (speed) as before (500 tire RPM).
Now to look at this another way if you keep your driveshaft RPM constant at say 3500 RPM. With stock gears this may have been at 130 MPH, now with say 3:73 gears this occurs at 95 MPH (130 * original ratio / new ratio).
Did I lose ya?
Did I lose ya?
