  • SN95 4.6L Mustang Tech
3 codes pulled (P0131,P1131,P1132), can someone help.
  • Thread starter Thread starter ajcolv
  • Start date Start date Jun 3, 2004
ajcolv
286
Utah
Jun 3, 2004
  • Jun 3, 2004
I first started getting the CEL when I swapped in my O/R H and didn't put on the MIL's. I ran it for several months and then swapped the stocker back in when Emissions and Inspections was coming up. After I replaced the O/R with the stock H, I still had a problem with the CEL. I haven't noticed any drivability problems, but don't drive it very often. I got the following codes when I went to Autozone (P0131,P1131,P1132). After a search I found info on the P1131 code, which is probably the o2 sensor as I suspected. I wasn't able to find anything on the other two codes. Can anyone help me determine what the problem would cause that combination and how to attempt to fix it?
Thanks in advance,
Aaron.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 3, 2004
  • Jun 3, 2004
http://autorepair.about.com/cs/generalinfo/l/bl827d.htm
common problem on fords. looks like your MAF is dirty probably from your K&N
03gtmustang
923
Northern Va
Jun 3, 2004
  • Jun 3, 2004
How do you clean your maf sensor, if that doesnt work then where and how much could someone get a new one?
M
MustangLife
1,285
Chattanooga, TN
Jun 3, 2004
  • Jun 3, 2004
Ford does not recommend you clean your maf sensor. I think the only real way to fix it is buy a new maf or use some kind of electronic cleaner something safe on sensors.
Josh
03gtmustang
923
Northern Va
Jun 3, 2004
  • Jun 3, 2004
Anyone know how much they cost? Im curious because I had the c&l MAF on my car for a little while and it ran fine, no engine light or anything. Then I installed a accufab 75mm t/b and c&l plenum and my car started running lean. So I took off my MAF and went back to the stock airbox, but now my car is still running lean. Every once in awhile while im idling my rpms will fluctuate pretty bad between 300-800, but once it warms up a little its fine. So pretty much I cant just turn my car on and go, I have to give it a couple seconds. But the engine light wont go off.
Tylerb59
Banned
Mar 7, 2003
1,895
Arlington, WA
Jun 3, 2004
  • Jun 3, 2004
Check this out for the MAF:
http://www.bullittarchive.com/Maintenance/maf/
ajcolv
286
Utah
Jun 3, 2004
  • Jun 3, 2004
Well, that's the problem. I no longer have the K&N and when I did, I did clean it. I tried the way the link you suggested recommends and also using brake cleaner. I don't if anyone found anything different out but brake cleaner was recommended because it doesn't leave a residue. Anyway, so from what I'm getting it's probably not the o2 sensor but the MAF now. I might have to run to a pick and pull and see if I can get one from a junked GT. Does anyone know if it has to be from a 96-98? If that doesn't work then I'll have to try the o2 sensor. I've also heard that it might be the gasket between the header and the h-pipe. Does that sound like that could be a problem too?
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
R
93 LX 2.3 Trouble codes 53, 85, 21 help
  • Rickshaw302
  • Apr 15, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 18, 2025
AeroCoupe
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Engine Ultimate mystery need help
  • saleen92sc
  • May 15, 2022
Fox 5.0 Mustang Tech May 16, 2022
Pinellas50
P
