  • SVT Tech Forum
3 inch wheel studs?
  • Thread starter Thread starter sweet96cobra
  • Start date Start date Mar 11, 2008
sweet96cobra
  • Mar 11, 2008
Hi every one. I just purchased 1 1996 SVT Cobra that has 3 inch wheel studs on all four hubs. The previous owner was running (American Racing Wheels on it for the track) I want to put my 03 cobra rims on 17x9---17x10.5. Do i have to remove the 3 inch studs and put standard size studs in? or is there a way to keep the 3 inch studs and still make it look nice by using open end lug nuts? And if so, what special tools will i need to remove and install the new studs?
Thank you
sweet 96cobra
blackfang
1,290
Richmond, Va
Mar 11, 2008
  • Mar 11, 2008
You have to remove the studs in order to use a non open ended lug nut unless someone makes or you can use a long shank lugnut.
sweet96cobra
  • Mar 11, 2008
Thanks
Thank you blackfang ( nice looking cobra you have). I went ahead and ordered the installation and removal tool from C2 racing. I will go with the standard studs and be finished.
Thanks again
sweet96cobra
blackfang
1,290
Richmond, Va
Mar 11, 2008
  • Mar 11, 2008
Thanks again
sweet96cobra
Not a problem and thank you.
What tool is this? I have always used an air hammer to remove the studs and a c clamp to install them.
sweet96cobra
  • Mar 12, 2008
tools
http://mustangwheelspacers.com/index.asp?PageAction=VIEWCATS&Category=10
I'll see if they work, otherwise hammer and c-clamp.
sweet96cobra
blackfang
1,290
Richmond, Va
Mar 12, 2008
  • Mar 12, 2008
Honestly those are a waste of money. You can cut off the stud with a grinding wheel and hammer it out and use the c clamp /w deep socket to pull the new stud through.
Of course you could see if AZ has these tools you can borrow.
sweet96cobra
  • Mar 12, 2008
3 inch studs
Thanks again. I will cancel that order for the tools, they looked a little weak any way and that removal tool would probably not work on a 3 inch long stud. Grind, hammer,clamp.Sound's good to me.
sweet96cobra
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Wheel help for a 1994
  • StevieStang
  • Nov 23, 2022
1996 - 2004 SN95 Mustang -General/Talk- Nov 25, 2022
Mustang5L5
Should I Get a New Clutch Fork and Pivot Ball Stud?
  • AeroCoupe
  • Dec 18, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2022
96pushrod
  • SVT Tech Forum
