I am hopefully buying a 90lx 5.0 5spd this week. I have not test drove the car yet, but I think that it will run rich with the 30#er's on it. The mod list is as follows:
chrome 17' saleen rims less than 7000 miles on them
khumo tires (all weather) 265 40 17 front 285 40 17 rear less than 7000 miles on the
new euro style headlights
custom alluminum shifter knob
new 5.0 short block less than 7000 miles on it
gt40p heads
p style headers( ford motorsports)
bbk cat-less h pipe
flowmaster 40 series mufflers
e cam w matched valvetrain (ford motorsports) springs, lifters, pushrods
1.7 roller rocker ( crane energizer)
30lb injectors (ford motorsport)
cobra upper intake
gt40 lower intake
cold air intake
superchips performance module( not installed)
77 mm pro m mass air
edlebrock 70 mm throttle body
new bosch platinum plugs
new 8.5 mm racing wires
new msd blaster coil
new msd 6al ignition box w adjustable rev limiter
new cap and rotor
new mass air sensor
no smog
new alternator
new water pump
new oil pump
new double roller timing chain
new ignition modual
355 motorsport gears
bbk adjustable clutch quadrant
zoom kevlar clutch pressure plate and throwout bearing
new fan clutch, (electric fan is availible if specified, aditional charge for parts)
raidiator flush
new mobil 1 synthetic 5w 30 fram oil filter
If I purchase this, it will only be a DD, nothing more. I have my "drag car". I was thinking about swaping out the MAF and injectors for a stock set I have laying around. Maybe try to make some money off of it. I don't think the 19's will be to small... But what do y'all think?
gt40p heads
bbk cat-less h pipe
cobra upper intake
gt40 lower intake
cold air intake
new cap and rotor
new mass air sensor
no smog
new alternator
new water pump
new oil pump
new ignition modual
raidiator flush
bosch=
