  • 1994 - 1995 Specific Tech
300 rwhp
  • Thread starter Thread starter 302fordracer
  • Start date Start date Mar 31, 2004
1 of 2 Next Last
302fordracer
738
Vancouver, WA
Mar 31, 2004
  • Mar 31, 2004
Hey, can anyone out there tell me how with 2000 bucks I can get my 1995 mustang gt to 300 rwhp. I have a limited budget for the next few months and need a quick boost in ponies.....thanks guys (oh and the car is currently stock other than k&n filtercharger and 14 degree advance).
302fordracer
738
Vancouver, WA
Mar 31, 2004
  • Mar 31, 2004
sorry guys but now that I think about it this isn't really my question because asking it is stupid because it has been asked hundreds of times....my real question is what brands are the least expensive and most effective for this type of work. So many people have offered suggestions as to the necessary parts but what I really want is someone running nearly 300rwhp or better to tell me the brands and how to get them as cheaply as possible....thanks
R
Road_Runna
20+ Year Stangneter
Dec 23, 2002
594
Ogden, UT
Mar 31, 2004
  • Mar 31, 2004
Nitrous.
but if you don't wanna get that, then can I ask, are you going to do all the work yourself, or are you gonna take it to some shop, and pay for the work?
Smeckel
751
Meriden, CT
Mar 31, 2004
  • Mar 31, 2004
Just search around on ebay and the classified here and at www.corral.net. You should be able to get a H/C/I combo and the supporting parts for a little bit over 2000 if you are a good shopper. A decent combo will give you around 300hp. But nitrous is defeintly the easy way to get there and it'll probably cost you 1/2 as much.
Venom351R
4,548
41
98
MAINE
Mar 31, 2004
  • Mar 31, 2004
Heads will be the most important factor in this combo. Trick Flow heads are AWESOME and they are cheap $995 from Mustangs unlimited VS about $1,200 + for AFR Heads. With the right cam TW heads will out preform AFR heads. I have 2 friends, one w/ a 91 LX the other w/ a 91 GT. The 91 LX has all the basic bolt ons and full exhaust, TW heads, Ported Cobra Intake, and an alphabet cam a B cam I think he dynoed at 299 and to 291 ( diffrent dynos) The 91 GT has full exhuast and basic bolt ons only diffrence being he has cats and a diffrent cam. For heads he as AFR's GT40 Intake and I belive a crane cam, he dynoed at 270 on the dyno that the LX dynoed 291. so point being if you put together the right combo you can come close to 300 on the dyno.
Dont get Nitrous, it may be the cheapest way but you only have that power when your bottle is full.
9
95.0Stang
538
Kansas
Mar 31, 2004
  • Mar 31, 2004
GT40 intakes are pretty weak though compared to a Trickflow or Edelbrock set up.
Somebody around here is selling the Trick Flow engine Kit for $2039 I think, you should get ahold of that, and you should have the 300hp you desire!!!
Smeckel
751
Meriden, CT
Mar 31, 2004
  • Mar 31, 2004
The engine kit can be purchased at alot of places including www.summitracing.com but you will need to buy things like injectors, mass air, fuel pump, throttle body, ect... so if you go that route and buy all new, expect to spend closer to 3000.
9
95.0Stang
538
Kansas
Mar 31, 2004
  • Mar 31, 2004
either way you go back to the old saying...you gotta pay to play
9
95.0Stang
538
Kansas
Mar 31, 2004
  • Mar 31, 2004
use the stangnet trader and corral to find the other parts and you will spend closer to $700
L
limit
17
#10
  • May 14, 2004
  • #10
solution but not pretty
http://www.carcraft.com/techarticles/116_0307_ford/index.html
this combo will get you 330rwhp
if you shop smart you can get all the parts for under $2000. only problem is that no one wants to carb daily drivers anymore. i dont mind im constantly on the highway...
GTJake
3,049
Ann Arbor, MI
May 14, 2004
#11
  • May 14, 2004
  • #11
You could turn that statement right around also. We'll see this summer...
Jake
94TURBO5 O
2,509
VA
May 14, 2004
#12
  • May 14, 2004
  • #12
$700 for a good n2o set up. You can leave your car basically stock and have the xtra power at your fingertips. Upgrade your fuel pump and you'll be able to do more upgrades and mods for $1300.
F
Fast94Cobra
385
Atlanta, GA
May 14, 2004
#13
  • May 14, 2004
  • #13
another vote for nitrous here if you want quick power at the track.
if you want a cheap/good HCI i would get the trick flow package. all brand new parts for 2 grand, pretty good deal
stack
174
Rochester,NY
May 14, 2004
#14
  • May 14, 2004
  • #14
The powedyne supercharger kit can be had for 2100 or so. That should about do it.
stack
OinkAodeOink
3,026
Daytona bch, Florida
May 14, 2004
#15
  • May 14, 2004
  • #15
if you shop around you can pick up a used blower kit for under $2k
I found my S-trim setup for $1800 used ( sold it for $1600).. Worked perfect, and never had one problem with it ( other then the typical blower belt probs).
Then bought a new GSS340 pump( $110)
and ran the FMU on the stock injectors
Few weeks later i had it dynoed, and made 316RWHP on that simple setup, through an AODE, untuned. I was running on 19lb injectors which were pushing it, but it worked just fine. went from a 15.3@92 to 13.30@109
95snoozer
2,572
RCR
May 14, 2004
#16
  • May 14, 2004
  • #16
no way in hell!
1slow95
1,797
ohio
May 14, 2004
#17
  • May 14, 2004
  • #17
If you can do it all yourself, a junkyard twin-turbo can be done for under $1000. Check this out... http://www.wildstang.stangnet.com/index2.htm
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
May 17, 2004
#18
  • May 17, 2004
  • #18
A very similar story is in 5.0 Mustang Mag this month. Guy searched out and acquired two Garrett T-3's, did some ridonkulous welding, and yanked 450 horses out of his engine real quick. Pick up the magazine, it's got a whole pile of info on what you need, and what tools you're gonna have to use. I'm thinking about going that direction now, so long as i can polish the old turbo's.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 17, 2004
#19
  • May 17, 2004
  • #19
Heres a powerdyne for sell under 2000 http://classifieds.stangnet.com/showproduct.php?product=180&sort=1&cat=3&page=6
Good luck.
Imyourzero
Learned that lesson as a horny teenager with lots
2,298
Hoonose, U.S.A. Posts: 39,051
May 18, 2004
#20
  • May 18, 2004
  • #20
And with the right cam, AFR's will outperform TrickFlows.
Like Jaden on the Corral who makes 312rwhp with AFR's and the same cam that I have. I think he actually has LESS mods than I do, so I'm expecting some nice numbers after the AFR's go on this week.
TrickFlows ARE good heads for the money but there is a reason why AFR's come out on top in all the aftermarket head comparison tests. No sense in arguing about it though, bottom line is that you can make 300rwhp with either one.
Besides, dynos don't tell the whole story. There is a guy on Corral who dyno'ed at 262rwhp/255rwtq and ran a 12.3 @ 109 on his first pass...
1 of 2 Next Last
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
M
  • mnky99
  • Sep 5, 2025
mnky99
M
