25thmustang said:AFR or TFS heads, Ebrock or TFS intake, matched cam, and all the bolt ons. Should be easy 300 rwhp!
A question like that will bring out an answer as accurate as your average joe throwing darts. The general consensus with a full HCI combination (with moderately-matched streetable components) yield output in the 300-350 fwhp range.powermaxx said:how much hp will i get with this combo?
87'GTstang said:A question like that will bring out an answer as accurate as your average joe throwing darts. The general consensus with a full HCI combination (with moderately-matched streetable components) yield output in the 300-350 fwhp range.
8psi gives you about 100 HP to the wheels.So 14 would give him alot more.But stock heads and intake will severly choke his potential!!bynummustang said:I'd say just get a small vortech, with somewhere around 14 PSI. That should be right near 300.
afr 165 58cc chambers
edelbrock intake
longtubes
e-cam / 1.7 roller rockers
70mm mass air
24lb injectors
mikemustang289 said:Go to AFR's websight WWW.airflowresearch.com
There are aticles on combos with the 165 heads. 400fw hp should be a piece of cake with the 165's and a mild cam
There is actually an article there where they make 400fw hp and over 350 ft-lbs of torque from 3500rpm up on a used (completely stock) 5.0L and that's with the stock cam using out of the box AFR 165's with a CR of 9.0:1
Check out the articles
Even if you were to lose a very conservative 20% HP through the drivetrain and whatever you run off the crank, you're still looking at over 300hp to the wheels.
willys1 said:8psi gives you about 100 HP to the wheels.So 14 would give him alot more.But stock heads and intake will severly choke his potential!!
