• Community Forums
  • Regional Forums and Event Information
302-351
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Apr 5, 2008
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 5, 2008
  • Apr 5, 2008
So whats the H.P/T.Q increase from a 93 302 to a 74 351W with the exact same H/C/I on both motors? peace
john
breakemlose
244
Mexico
Apr 5, 2008
  • Apr 5, 2008
30hp?
Mustang78
486
Aberdeen, WA
Apr 5, 2008
  • Apr 5, 2008
at least 75, IMO..it's hard to just swap parts without upgrading, 75 isn't unreachable IMO
Bullitt347
I have been doing it wrong this whole time
4,020
3,018
204
Middle of Maine
Apr 5, 2008
  • Apr 5, 2008
A good rule of thumb is 1 h.p per cubic inch if all else remains the same. I would guess a bit more than 1 lb/ft torque per cube because of the added stroke. All of the extra cid is coming from stroke not bore.
stock50LX
Curmudgeon
1,858
University Place, WA
Apr 5, 2008
  • Apr 5, 2008
I think only 20 hp or so. The same HCI means you are running 302 parts. If you run 302 parts in a 351, it will run like a 302.
I assume you mean a '93 HO 5.0 engine...?! The 5.0 has 9.0 to 1 compression with 63cc heads. The '74 351 pistons have a huge dish. That engine is made for 8.2 to 1 compression with 60cc heads. So, if you have stock pistons in both engines, and heads with the same chamber size, the comparison will not include equal compression ratios.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 6, 2008
  • Apr 6, 2008
I havent measured the pistons in the 351 but the cylinder walls are in great shape still some good honeing marks the tops of the pistons are stamped 40? So maybe 40 over? I just need a idea on a cam and lifter set to put in it'll have GT40P's ported polished with 1.6 roller rockers, trick flow R upper lower intake acufab 70MM T.B C&L76MM MAF 24# injectors. I'm going to stay non roller and want a nice loppy cam but also hope for 400/400 or more at the wheels N/A
stock50LX
Curmudgeon
1,858
Apr 6, 2008
  • Apr 6, 2008
Try a Motorsports A351 cam. It is hydraulic flat tappet, about $75. through Summit. I ran 11's with that cam and a low compression 351 (EFI) . Your pistons are .040 over. You can go to .060
lamrith
1,386
Tacoma, WA
Apr 6, 2008
  • Apr 6, 2008
Also the Intake will not fit from a to a 5, taller deck means wider valley. Heads yes, cam maybe yes, but not lower intake. Like someone said, heads intake will cost you much power, not even worth the trouble of the swap.
You could probably spend all the $ for the 351 and swap parts on better H/C/I for the 302 see higher net increase...
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 6, 2008
  • Apr 6, 2008
I know what will and wont fit the 2 engines. I didnt mention i will be getting the 351 trick flow R intake the heads will work just need to drill the bolts out.I just needed to know what cam to install. The heads are to just get it going for now, i want to eventullay go 408 with a nice turbo? I'm getting it to the running and bug free point over the next 2 years till i go back east for good. peace
john
Mustang78
486
Aberdeen, WA
Apr 6, 2008
#10
  • Apr 6, 2008
  • #10
my GT40's had 1/2" head bolt holes, so you might not need to drill em...
S351Saleen77
423
Washington
Apr 6, 2008
#11
  • Apr 6, 2008
  • #11
If you want 400/400 @ the wheels OR More you would need more than 450hp @ the crank. I don't see that with your heads.
Heres a link to Edelbrock and their packages. They got 451hp and 433tq but they had to step up on the heads. I didn't look at the cam specs. Their dyno chart does not seem to come up though. This still wouldn't give you 400 in torque @ the wheels. I have never heard of these heads either, RPM XT? They must be a ported version of the RPM's.
Victor Jr heads will make the power you are after, I just don't see it happening with your heads at all.
http://www.edelbrock.com/automotive_new/mc/power_package/tek_ford.shtml
M
Midnightmotorsports
126
NE Portland, Or
Apr 6, 2008
#12
  • Apr 6, 2008
  • #12
I have a set of lightly used (about 3000 miles) SRP .40 over forged full floating flat tops with rings. $100 That would bump your comp up for some more HP. Toss a Motorsport F cam in there and you should be close to your goal IMO.
S351Saleen77
423
Washington
Apr 6, 2008
#13
  • Apr 6, 2008
  • #13
This is a great cam. Duration @.050 is 236/246 with .520"/.538" lift. They installed it with a 2 deg retard in the 351 HO crate engine with the J302 alum heads they made 385hp, 377ft lbs. http://www.mustangandfords.com/techarticles/28939_351_ho_svo_crate_engine/index.html
This cam is 226deg@.050 with .512" lift but he does not have a late model roller block. The Z303 is 228deg@.050 and .552" Lift.
Anyway John I don't think you will make 450+ hp with any of these cams and your heads.
But what do I know anyway??
stock50LX
Curmudgeon
1,858
Apr 7, 2008
#14
  • Apr 7, 2008
  • #14
The A351 cam is pretty lopey, but I used a stock A9L, no chip.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 8, 2008
#15
  • Apr 8, 2008
  • #15
I'm not useing a chip either. peace
john
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 8, 2008
#16
  • Apr 8, 2008
  • #16
I just got off the phone with summit and that cam has been discontinued? Do you have a part number or whats the specs on it maybe to cross it with another brand? peace
john
fiveohwblow
Official Member
2,169
145
155
Apr 8, 2008
#17
  • Apr 8, 2008
  • #17
If you cant find it Ed Curtis made a phenom cam for me. I love it...
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 8, 2008
#18
  • Apr 8, 2008
  • #18
Any contact info? decently priced? thnaks man. peace
john
"Mongoose"
21
Vancouver,Wa.
Apr 8, 2008
#19
  • Apr 8, 2008
  • #19
Comp Cams make a large selection of cams for your 351w. There tech guys
can really help you pick out the one you need for your set up.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 8, 2008
#20
  • Apr 8, 2008
  • #20
i was trying them also next. thanks for the info justin. roger are you going saturday? i'll call ya thursday have last night of bowling for this season tomorow. peace
john
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
D
351w swap shifter is not lining up
  • duckman0926
  • Aug 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 7, 2025
limp
  • Community Forums
