302 in a 79 4x4?
Killer50stang
632
I found a 79 f-150 and the guy says it has a 302. The truck is a 4x4. I wasn't aware ford made a 4x4 with the 302. Anyway, I assume this is still a T-5 tranny. Will this work on a mustang since it has a transfer case attached. Can I just unbolt the transfer case and used this tranny? Also, how can I find out what type of heads are on this motor? Thanks.
Jason
just going to let you know if i change a carb on my motor, that doesn't mean i got better heads. you can use any carb with stock heads. it's not often to see nice heads on an old 4x4. at least that i seen, i am sure people do it but if it were me i wouldn't.
This is funny. People do it all the time. As stated above, this motor isn't from the truck, it came out of something else. I know this becaus the owner told me. The cab isn't from the same year either. Do you need me to prove it? Who gives a crap if it's stock or not. Is that the title of this thread?
Jason
:hail2: Thanks captain obvious! Oh, and thanks I'll put an 850 carb on a stock motor and I'm sure it'll run fine. Too much fuel isn't good...Oh and I'll tell all the guys on ford-trucks.com that it's not often you see nice heads on a 4x4. Where are you from, Mars?
your the one asking if it has a t5. you going to believe the owner. lots of people don't know there ass from a whole in the ground when it comes to parts that may or my not be installed. go ahead and buy it. then take it apart and look at the heads. probably stock. you asked which heads are on it. if they were aftermarket, how the hell is anybody going to know what they are unless somebody looks at them. are you saying this thing has an 850 carb on it. that's way too big. again you believe that that motor isn't out of the truck. how do you know. did you keep tabs on it since 79. if you wanna tell, look at the numbers on the lower drivers side of the block where the tranny bolts. it will give you a rough idea. did he crank it for you and did it sound aftermarket. just because it may have a cam,intake and carb means nothing. lots of people do those things and don't touch the heads. damn i better watch out before FTE members come run me down with there hopped up 4x4. i'm just calling it as i see it. if you read it right before you popped a vessel in your eye, i was saying that i have never seen any trucks with aftermarket heads and i would never do it since it aint a racetruck and the trucks and 4x4 i had had plenty of power for what i needed. i also many people probably do it.
This is pointless. What the hell does a carb, cam, etc have to do with the heads? Did I say this stuff was on the motor? My point of this thread is how to find out what kind of heads these are. Did I ask what heads on on this motor? NO!! Next time, read! I wanted to know, how I can tell what kind of heads these are, plain and simple. I never said anything about any other mods being on the engine, especially it being the reason of it not being stock. I had never heard of a 302 in the 4x4 models. It's usually a 351M motor and the 302 in the 2WD's if it had a V-8 motor, otherwise, it was a 300 straight 6. I asked if it was a T-5, because that's what the 302 uses on manual transmissions, but I wasn't sure since it was a 4x4, which uses a transfer case. I think you need to pick up one of the 4x4 magizines. You'll find many reasons why you add mod's to a 4x4. I am buying this truck for parts by the way to finish my 78 project. Is it so hard to ask a simple question, without getting some moron to ask you another dumb question? Fact is, I asked a simple question, and got you who gives me bull S* about other mods. Do I care? What did I ask? Next time, don't reply!! :lol: :lol: :lol: :lol:
you need to read up on some info. there is no reason why a 302 was not put into a 4x4. it is dumb to think just because it is a 302 that it must have a t5. there has never been a truck(2wd or 4x4) that used a t5. sounds like you need to read up on 4x4 magazines. you said the motor isn't stock. that means modified parts. if you meant the motor is not the original, then say so before you confuse everybody. this is why everybody thought it was modded. it was my bad on the carb thing. i thought you just mispelled carb instead of cab because i didn't know why the word cab would be a part of this thread. i told you where to look on the heads. you need to READ better. what good does a modified motor do on a 4x4 in the mud, it's all about traction. too much power and too little traction equals stuck. this is one of my reasons for not modding my old 4x4 motor. the other is because i don't race it. what good is a powerful motor if it already has enough power to do what i want it to stock. start reading up. again i already told you where to look to find out what block and heads you have way before you lost your cool. take you head out of your ass and scroll up. are you done yet.
I said I never heard of a 302 in this year of a truck being a 4x4, I never said they didn't exist. Again, does all this bull amount to the topic? I simply posted, because I wasn't sure about the tranny and heads, which was my purpose. I didn't know if there was a T-5 that had the cabablility of mounting a transfer case, just like the C-6. OH well, just communcation error. No hard feelings.
Jason
