302 RWHP and 322 ftlbs of torque :-)
Tramage
38
42
Lees Summit, MO
So my buddy bought a dyno and we strapped my mustang to it on Saturday. It was very busy so we only did 3 pulls. First one only pulled 172 hp (he forgot to turn the fuel pump on) Second pull was 297HP and the last pull was 302Hp. Does this sound right based on my list of mods? I only because I'm going on the word of the person I bought the car from on what mods are done to the motor. Any feedback is appreciated
Thank you
Heads are killing you. A 289 head is a "clog in the drain" regardless of the porting and oversize valves. A 347 is a 400 FWHP combination pretty much across the board given that you add a set of heads capable of flowing the air the increased bore and stroke are capable of sucking in.
So bottom line,... 302 rwhp from a 349 c.i engine is.......... anemic.
yeah
Yeah, heads are definitly on my to-do list lol Still trying to figure out what direction I want to take the car though. Need to figure out what heads will work well with my motor setup and actually verify my mod list lol
How does one go about just buying a dyno on a Saturday? Can I get one of those on Amazon w/ free shipping?
I do agree with Mike though, any well put together 331+ engine combo should be at least knocking on the 400hp door.
My buddy tunes high horse power cars here in Kansas City and was tired of using other shops dyno's so he bought one from DynoJet lol. Do u think it isn't a 349 or do u think the heads are whats bringing the numbers down?? Like I was saying befor my list of mods are not confirmed yet so :-/
No expert here, but i'm hoping for 300-310 rwhp if i ever dyno mine. Like stated above, your heads are killing you, as mine are doing the same to mine.
Joe
Killing him, or not. I bet you its a very torquey engine. I'm not expecting that much more horsepower out of my 331 with mildly ported GT40X heads, but I do have a 10:1 cr, a Trick Flow Track Heat and CompCams XE274HR bump stick to help it along. I'd be pretty content with 330-340rwhp and like amounts of torque or so.
Torque is where it's at. That's what you feel when you mash the go fast pedal. 322 ft/lbs in these cars feels like a whole lot more than that. I ended up close to 400 ft/lbs after the blower/tune, the car feels like a monster...
Someone told you wrong on your heads.
There was no "HiPo 289" in 1969.
There was no 289 in 1969, period.
Also, you cannot put 2.02" valves in a 289 head.
There is barely room for 1.94" valves.
What intake are you running???
I don't agree with that statement in general.
In the case of this engine, I do, as he really has no idea what he has...
However, old timers like me remember when there was no such thing as aftermarket heads for SBFs, and believe it or not, there were some fast/high horse engines back then... It was just harder to do.
Well Rate if there ever was an old timer, it's me. I have experience w/ a professionally hogged set of C9Ae 351 W head sporting 2.02/1.6's on my last 351w engine.
( Definitely NOT 289 castings)
Just changing to a cast iron World Senior head picked that car up 5 tenths. I don't know how much HP that equates to,....but it is definitely the definition of removing a "clog in the drain" for me.
I never said aftermarket castings weren't better, just that they weren't always an option, and that even then you could build a strong engine.
General rule of thumb:
.1 in the quarter = 10 rwhp.
Therefore an improvement of .5 is approx 50 rwhp.
349 CI small block Ford
Eagle I Beam Rods
Kenneth Black Flat Top Pistons
Holley 750 double pumper
1969 Cast 289 HiPo heads heavily ported W/ 2.02 Intake valves
Bee Hive valve springs
SVO 1.6 mm roller rockers w/ ARP studs
Comp xe282 cam
GM one wire alternator
AC delete
Power steering delete
Electric Water pump
Electric fan
MSD 6-AL+ ignition box
MSD Pro billet distributor
Mac Shorty headers
Mac Offroad H pipe
Flowmaster 40 series Dumped
A 289 equipped like this (assuming good intake), should hit 302 rwhp.
I wonder where the other 60 cubic inches are hiding... ???
(This is before aftermarket heads too... It should be around 400 hp as noted above with even a modest set of aftermarket heads. A friend (of my son) has a 331* that just dyno'd at 540 fwhp n/a)
*331 stroker in a 4.125" bore Dart block, therefore CID is 345ish
I'm running the edelbrock performer intake and is there any casting marks or numbers or anything I can look for to try to find out what heads are on it?
With only 302rwhp and 322rwtq, I seriously doubt that your engine displaces 349ci. It's far more likely to be 308ci (+0.040" overbored 302) instead.
Why? How many 351W with factory Ford iron heads (even ported) have you seen make over 300rwhp? I'd say his horsepower and torque figures are right on the money for the parts he's got.
Reactions: Tramage
God how I wish that were true..................it would be so easy to run with the big boys in Top Fuel without needing over 8,000 HP!
