302 shortblock in sw burbs Chicago
VicRattlehead
519
ChiTown Il
Ford 306 shortblock plus some extras: pictures show valve covers, intake and oil pan, but the auction DOES NOT INCLUDE VALVE COVERS, INTAKE, OILPAN OR PICKUP)
It does include the timing cover, harmonic balancer, and flexplate.
Rods: stock ford
Pistons: Probe flattop pistons
Bolts: ARP
Heads: World Products Heads (p/n 710032 casting number I-057 W J/R) See tech specs below.
Cam: Elgin Industries (see specs below) (according to World Products they are the same casting as the Iron windsor jr heads they currently list on their site, but they are aluminum)
Head Technical Specs:
Casting ID Number: I-058
Material: aluminum
Valve Seats: Intake (integral), exhaust (hardened)
Valve Guides: Integral cast iron
Spring Seats: Machined for 1.560" and 1.250"
Valves: Manley stainless steel valves in assemblies (inconel exhaust valves on marine applications)
Valve Diameter: 1.940" intake, 1.600" exhaust (11/32" stem)
Guide Plates: Special World part #830460-8
Rocker Arm Studs: Screw-in style
Rocker Arms: Adjustable rockers recommended. 1.6 ratio (use of 1.73 ratio will require elongation of pushrod holes)
Intake Runner: 180cc, standard port location
Exhaust Ports: 64cc, standard location (dual exhaust bolt pattern to accommodate large custom headers)
Combustion Chamber: 58cc
Spark Plug: 14mm 5/8" .460" reach tapered style
Valve Job: Multi-angle intake and radiused exhaust
Valve Cover Rail: Raised
Valve Angle: Stock 20°
Accessory Bolt Holes: Stock
50-State Emissions legal
Spring Specs
1.250": 100 lbs. @ 1.810", 300 lbs. @ 1.250", coil bind @ 1.200", max lift @ .570"
1.437": 125 lbs. @ 1.810", 340 lbs. @ 1.210", coil bind @ 1.160", max lift @ .600"
1.550": 200 lbs. @ 1.900", 480 lbs. @ 1.200", coil bind @ 1.150", max lift @ .700"
Head Flow @ .600 Lift
236 intake, 169 exhaust (Super Flow 1050)
254 intake, 176 exhaust (Super Flow 600)
All heads flowed with a standard .750" intake plate, without exhaust tube, and 28" of water.
Cam Details E-1018-P:
Range Part Number Direction Cam Int Valve Int Advdur Int Timdur Int Open Int Close Int Overlap Lash Int Center Int Cyl Footnote
C E-1018-P INT .318 .509 300° 222° 5° BTC 37° ABC 79° HYD 107° 8
EXH .332 .532 309° 232° 55° BBC 3° BTC 117°
here are some pictures. again, intake, oilpan/pickup, and valve covers do not come with the engine.
302ford pictures by perrace - Photobucket
$3499
can probably deliver to nmca st.louis race.
815-254-2333
[email protected]
if your interested in this i can make a deal on it, i can also complete it to make it a running longblock with whatever components you want on it, at additional costs. i can meet or beat the major parts catalogs pricing on most everything. let me know.
tax season is here put your return to use!!
still have the motor just sitting on a stand in the back of the shop. It's never been installed in a car just had a few hours of dyno time testing out some timing chains. good 400hp motor for your project.
