  • 1994 - 1995 Specific Tech
306 dyno results
  • Thread starter Thread starter 95Vert
  • Start date Start date Jun 19, 2006
1 of 2 Next Last
95Vert
1,785
North Mexico (deep south Texas)
Jun 19, 2006
  • Jun 19, 2006
A buddy of mine just got his 306 dynoed and made a whopping 258hp and 280tq. He's got gt40p with 3thing valve job, 1.6s roller rockers, ported, f-cam with holley systemax intake and shorty headers with h-pipe. he's got the stock inj, maf and gears with a 5-sp. He set the timing at 12*. They found a problem with his ect. They told him he was running rich because of this and causing power loss. Does this sound right? What should he be at?
Thanks
TheRedBlur
15
seattle
Jun 19, 2006
  • Jun 19, 2006
cars that are built, need tuning. was it a mustang dyno or dynojet? just curious.
95Vert
1,785
Jun 19, 2006
  • Jun 19, 2006
probably a dynojet. i pulled 240/260 with my combo when it was auto.
Guero
2,148
Jun 19, 2006
  • Jun 19, 2006
whats the power difference form a 302 and 306?
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Jun 19, 2006
  • Jun 19, 2006
20hp plus or minus a few
Guero
2,148
Jun 19, 2006
  • Jun 19, 2006
hell yeah!!!!!!!! lol
bill302
2,131
alabama,gadsden
Jun 19, 2006
  • Jun 19, 2006
it has to be running to have the extra horse power guero.lol.
Guero
2,148
Jun 19, 2006
  • Jun 19, 2006
basterd!!lol it will be soon!!!!
95Vert
1,785
Jun 21, 2006
  • Jun 21, 2006
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 21, 2006
#10
  • Jun 21, 2006
  • #10
302 to 306 hp difference is maybe 3-5hp.
Timing could probably be a bit more than that...try 14* or so...
GRGT1994
1,034
#11
  • Jun 21, 2006
  • #11
About 4 cubic inches.
Zero Signal
2,633
Tucson, AZ
Jun 21, 2006
#12
  • Jun 21, 2006
  • #12
I think the 20hp came from the assumption that you are replacing an old worn out stock shortblock with a very well built 306.
Guero
2,148
Jun 21, 2006
#13
  • Jun 21, 2006
  • #13
yeah mine had 150,ooo miles on it
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 21, 2006
#14
  • Jun 21, 2006
  • #14
I didn't gain anything with my 306 and longtubes from my old 162k bottomend.
I also added a ported intake, which I attribute to the gain of the .51 mph I gained after those additions.
The new engine was probably pretty tight, it had about 1000 miles on it.
A loose engine has less friction (lots of miles) and can free up some horsepower.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 21, 2006
#15
  • Jun 21, 2006
  • #15
ya i think any gain from 302-306 would be from bad/worn rings and going to a better rotating assembly and oiling system
TheRedBlur
15
seattle
Jun 21, 2006
#16
  • Jun 21, 2006
  • #16
actually, a loose engine has more friction from improper oiling and increased vibrations.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Jun 22, 2006
#17
  • Jun 22, 2006
  • #17
The Holley intake is not the best choice for that combo.........
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 22, 2006
#18
  • Jun 22, 2006
  • #18
Talk to the Pure Stock guys, as 25thMustang says..."loose is fast"...
Many know tight engines can eat up a bit of power...
TheRedBlur
15
seattle
Jun 23, 2006
#19
  • Jun 23, 2006
  • #19
Loose is fast is a term referring to driving style, not sloppy engine build. Loose is when you are cornering at the car's limits, and it slides a bit, with cars like ours, we usually oversteer a bit. Loose is a term referring to oversteer. When a car is loose, you are swinging it around the corners, maintaining your momentum, making higher speeds on the straights, "tight" cars that understeer, will plow the front end through turns, scrubbing off momentum that needs to be built up again during the straights. I wll agree with you on this though, an engine with too tight of clearances will eat power, that would be an improperly built engine, but the same goes for too much slack. An engine with loose connecting rods will rattle and not sustain high rpms or horsepower. An engine with loose tolerances on the main bearings (crankshaft) will have a crank that vibrates excessively, ruining harmonic dampers and wearing the timing chain/lifters and valveguides. Not just that, but the crankshaft would walk back and forth in the block. I could go on. If loose tolerances were beneficial to engine builds, then everybody would be doing it, and burning a lot of oil in the process. I know for sure that Panoz, with thier 7000+ RPM 5.0 that they used to run a few years ago, generating about 500 N/A horsepower did not have loose engine tolerances. that goes for LeMans endurance racing as well as Trans-Am and Grand-Am cup. hell, the same goes for nascar and top fuel. If you still don't believe me, go ahead and call a local performance engine builder.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jun 23, 2006
#20
  • Jun 23, 2006
  • #20
:Word:
Make sure if it gets the right tune you post back the results.
RC
1 of 2 Next Last
New TFS top end build article
  • FastDriver
  • Feb 3, 2024
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2024
FastDriver
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
Fox Am I The Only One Shocked By My Dyno Results?
  • Vinnyc1487
  • Sep 8, 2021
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2021
revhead347
F
1993 Cobra flooding
  • FireFoxCobra_SVT93
  • May 20, 2022
6K
Fox 5.0 Mustang Tech Mar 11, 2023
nickyb
Engine Cam idle and timing questions - big cam, little knowledge
  • Justin87
  • Jul 6, 2021
12K
Fox 5.0 Mustang Tech Jul 31, 2021
Middleagecrisis
M
