308 or 306 ?
  • Thread starter Thread starter MattTheBat83
  • Start date Start date Apr 12, 2006
M
MattTheBat83
203
  • Apr 12, 2006
i was to get an engine of this size would it be ok to run some bolt ons and possibly 5 lbs from a sc?
D
Daggar
3,902
  • Apr 12, 2006
There's perty much zero difference as far as that goes.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 12, 2006
  • Apr 12, 2006
Leave as much sidewall as possible for cooling purposes IMO
J
jjd975
4,236
louisville,kentucky
Apr 12, 2006
  • Apr 12, 2006
Stay with a 306. No need to remove more material than needed from a weak block.
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Apr 12, 2006
  • Apr 12, 2006
so true!!!
soontobefastfox
275
Troy, Michigan
Apr 12, 2006
  • Apr 12, 2006
why not just keep it a 302 and get better pistons and save some money for the machine work, unless you already have the block machined.
M
MattTheBat83
203
  • Apr 12, 2006
i was thinking of getting something like this : http://cgi.ebay.com/ebaymotors/Ford...ryZ33615QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Yobi1Kanobi
559
  • Apr 12, 2006
well if you have wear on the block your going to need maching in order to get a proper seal. But I wouldnt go any more than 30 over giving you a 306. IMO it weaken the cylinder walls and cooling isnt as good either. There isnt much if any HP advantage between 302 and 308.
RBRANDX
110
Myrtle Beach, SC
Apr 12, 2006
  • Apr 12, 2006
If you ever plan on running any type of power adder, go ahead and upgrade to forged pistons.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 12, 2006
#10
  • Apr 12, 2006
  • #10
I wouldn't take any more off the walls than .030 (306) if your planning on boost. Do the .030 if you have a used block that hasn't been bored/line honed...do the 302 if you have a new block. Stock piston size...
You will be plenty fine, just get a good tune...
Not much difference in hp between a 302, 306, or 308...maybe just a few hp...
Good Luck
M
MattTheBat83
203
#11
  • Apr 13, 2006
  • #11
any more opinions?
STANGateURlilSS
716
USA & SANDBOX
Apr 13, 2006
#12
  • Apr 13, 2006
  • #12
you can bore a stock block .060 but then the walls get thin.. and they tend to run hot.. which with boost is a no no.. as stated before the difference between a 306 and 302 hp is marginal.. but if you have to bore the block do not go more then about .030.. hell if its a new block leave it alone.. just have it honed to make sure u get a nice ring seal.. as for 5 lbs of boost.. yes a stock block can handle 5lbs of boost.. just make sure it doesn't run lean.. so just make sure u get a good tune..
M
MattTheBat83
203
#13
  • Apr 13, 2006
  • #13
im thinking of buying one of these engines but im not sure what add ons i should get
http://cgi.ebay.com/ebaymotors/Ford...cmdZViewItemQQcategoryZ33615QQitemZ8054896621 Any Aftermarket Camshaft - $180
Forged Pistons - $350
TFS Main Stud Girdle w/ ARP Main Bolts - $200
ARP high-performance connecting rod bolts - $85 [/B]
i was thinking i should get the forged pistions, the cam, and the connecting rod bolts, but should i get the main stud girdle?(not sure what it is)
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 13, 2006
#14
  • Apr 13, 2006
  • #14
The main stud girdle bolts onto your crank caps and keeps everything tied together in case your block decides to crack...just keeps it less "messy"...
I wouldn't waste you money on it personally...good luck!
M
MattTheBat83
203
#15
  • Apr 14, 2006
  • #15
thanks but i should probably get the cam and forged pistions?
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Apr 14, 2006
#16
  • Apr 14, 2006
  • #16
ummmmmmmmm, of course
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
E
Engine EEC-IV Problems
  • EDDIEM75
  • Jun 13, 2025
  • 2 3 4
3K
Fox 5.0 Mustang Tech Jun 29, 2025
manicmechanic007
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
