30psi 4.6L
Twisted
387
Hansen,CT
I was watching this video of an EVO running 33psi on a 2.3L stroker motor. They said like 600hp and he smoke almost everything.
What would a 4.6L produce at 30psi assuming you built the motor to handle that much boost?
what seats are those on MPH's red mustang? .... i need some of those!!!!
Don't forget.....PSI is only a measure of backpressure in the intake track. 30psi on a 4cyl engine is going to be moving no where near the volume of air that 30psi on a V8 would You're filling twice as many cylinders and therefore backpressure would be of a lesser amount in comparision.
swl987 said:
whats a stroker motor?
stroke is the measure of how far up and down the piston travels in the cylinder. a stroker motor is simply taking a crankshaft and connecting rods with a larger stroke than stock and putting into your motor. doing this increases the length the piston will travel and therefore increases your displacement.
there is no real answer to this as the setup and exact spec would vary the output dramatically.
But if you assume that a 4.6 can be tuned to the same specific output then it would give you a better esitmate.
600bhp / 2.3 litres = 260.87bhp per litre
so
260.87bhp X 4.6 litres = 1200bhp
However in the case of the SOHC 4.6 it is unlikely to be able to match a lightweight 4 cylinder engine for specific out per litre. So 900-1000bhp would be a safer estimate.
There may well be no substitue for displacement but modern technology and tubo's sure can mess up the logic. In the 1980's Formula 1 race cars used to produce 1500bhp from a 1.5 litre V6 turbo. NOW THATS IMPRESSIVE.
