So been working on a 2000 4.6 gt 5 speed with cold air intake BBK 78mm throttle body under drive pulleys 42lb injectors NGK plugs after market coils sct tuner 325lph fuel pump working up to a 93mm turbo. Ok with that said the car did start and run ran rich for a few minutes then shut it self off not sure why! Waited till the sct tuner got there while installing tuner got to much fuel in cylinders hydro locked motor got fuel out tried again to start hydro locked again! Is the 325 pump to much for now? I'm going to take tuner out see what happens being car did start and run before the tuner!?
