2600 is to high? well i guess on the street shifting at 3000 is pretty common. The other thing i would do if i was you is i would call AFR. they have a shop that custom grinds cams for there heads. Talk to the tech guys there they will put you in contact with the guys they use to grind cams and have a custom cam ground specifically for your combo. Thats a way better idea then buying a generic cam from anyone.
