I'll put this as delicately as possible (for me at least).
10's should not even be part of the conversation yet.
Unknown cam, unknown bottom end, good heads, wrong injectors, undersized meter and intake on a mass air swapped t top.
I'd be surprised if it survived or even ran a 12 pass.
Can you really trust someone that put these parts together as combination to have done the cam and the shortblock correctly? It would be like saying someone that painted their car with a roller and brush did the body work and prep correctly.
10's takes a minimum of 425rwhp and that's for seasoned drivers with well put together combinations on drag cars. With 19's, you are at least 125rwhp short of that and my guess would be 150rwhp.
Cutting weight would help if the car ran 11.2 or 11.30, but other than that, it's a waste of time and all it will do is devalue the car, especially a t top.
Then let's talk about the chassis, 10's even takes massive power or extreme traction (maybe even both), the whole suspension will have be heavy duty, especially on a car that all it has is a T brace in the roof. If you like the way the roof panels sit now, you may not after a 10 second run without a cage.
I didn't see a transmission mentioned, a t5 isn't going to survive a 10 second run and an unmodified aod well...
Bottom line is that the ignition is the least of the worries.
A 10 second car is purpose built from the ground up.
Look around and see how many guys here have run 10's, it's not many and some have been doing this a long time. I don't buy into it when people say they have 10 second cars or power, but they never ran 10's. You either received a 10 second timeslip or you don't have a 10 second car, period, speculation is moot. I think 12's can be assumed and maybe in some cases 11's, but 10's, no way.
IMO, forget the quarter mile and get the engine together correctly with the right injectors, bigger meter and intake and make sure it runs well and reliable. Then shoot for 12's and work your way up.
I also think it would be insane to just slap nitrous on a very questionable engine.
