I need opinions.
I might/do have a chance at buying a brand new (never left the engine stand)built 331 for 6k-ish. It was built buy a local shop for a customer and now the shop has it (long story). Just wondering if you think it's a good deal and what power I can expect to produce. Here are the specs:
stock
girdled machined block, 4340 crank and rods, JE flat top pistons (10:1 compression),Trick flow high port heads, TFS R intake, Trick flow stage 2 cam, crane 1.6 rockers. It also comes with 75 mm TB, 255lph in tank, 30lb injectors, 6al msd, Canton 7 qt oil pan, new water pump.
I know I could get a DSS long block for 5100, but this engines already built and includes a lot more.
The motor was built with a 200 shot in mind. So how long do you think the stock block would hold up to the nitrous? I won't spray til after I get a new tranny and rear end though.
What power do you think i could expect all motor? The shop is telling me over 400 at the wheels. But I don't think so. I agree with what other people have told me, more like 325-350. How long do you think the tranny and rear will hold up without beating on it?
Also, will the canton oil pan fit in a vert with the extra bracing?
stock
