Currently running a 302 in a 92 fox with trick flow street heat top end package. A 70mm throttle body and a 76mm On3 turbo kit.
Problem is I have exceeded the life of the 302 block, and now I have the great debate of either a 331 stroker or a 351. Goal is to use the same top end and turbo kit. Building a 331 looks to be way more money to build. Would I be better off trying to build 351 with a 4 bolt main if I can find one. Goal is to see over 600hp. Will a 351 block hold up to this. If so what year blocks do I need to look for.
