332 code, car running funny
KamiKaziDK
555
Mesa, Az
When cruising at a constant speed my car has been stuttering and running funny, almost like a miss, but I know I don't have one. I ran the codes today and I got a 332 code for "Insufficient EGR flow detected" in my continuous memory. looked it up on the forum, but nobody else has driveability problems with the code....any thoughts?
When you're at part throttle, the computer lets in exhaust gas to be re-burned, thus making the exhaust a little cleaner. It's carefully metered, and the computer makes adjustments to compensate for the extra air flow. If the EGR sensor or valve aren't working right, the wrong amount of exhaust is let in and the engine will run rough. The sensor is sold separately from the valve (and is cheaper), so I'd recommend replacing the sensor first and see if that fixes the issue.
Before replacing anything, ensure the vac lines and wiring are intact. Make sure the position sensor voltage changes if you open the EGR valve (a hand pump can be used to open it with the Key-on, car off).
FWIW, if the code is present, the EEC should have shut off your EGR function (the allowing of extra timing and less fuel due to the inert gasses that should have been present).
