333 and 347 short blocks
David19d
15
I have 2 built short blocks ready to go.
The first is a 347. Roller 302 block .030 over, Wheeler 4340 3.4 stroke crank, Eagle H beam rods, Lunati forged dome pistons. Balanced to a 28 oz balancer and flex plate. The rods and pistons are used but where checked before any work was done. I also have 2 spare pistons to go with it and a romac balancer. $2200.00 as is.
The second is a 333. Roller 302 block .040 over, Eagle 4340 2.25 stroke crank, Eagle 5.315 H beam rods, Mahle forged flat tops, Billet timing set, x303 camshaft, aluminum main girdle, hv oil pump, Canton kick out oil pan for fox body, ARP main studs, timing cover set up for mechanical fuel pump or with out but it is included. ( I can also include the one needed for an sn95 if need be.) This one is internally balanced and comes with a romac balancer and zero balance flex plate. $3800.00 as is.
Heads are available for both as they both take inline valve heads. Cam options are also open. I can finish the assembly of either for another $500.00 and your parts or $500.00 plus parts. Shipping is extra as well.
301-247-9652 call or text
[email protected] email
Im in Hollywood MD 20636 for shipping. Either one will be at least 350#.
No sale.
Also have a .020 over 302 roller short block. Stock crank, rods, speed pro hyperutectic pistons, roller block, new cam bearings and freeze plugs. 1100.00
