1990Coupe
I covered my face with the "threw a rod" post.... don't do that to me!
What's up with the strange stroke? Nascar crank? What about the rods? Strange rod length... Trying to do a long-rod setup or did you just get a good deal on them?
What bore and compression? What rpm are you running it too. Those heads and intake will want north of 7000 rpm.... maybe even up to 8k. What cams specs did you go with?
If it's leaking oil, wouldn't it pretty much have to be coming from the lower intake seal since you had a dual-plane on the dyno?
This is a progress thread. Let's keep it on topic, please.
I thought you are supposed to use bronze or composit gears with the hardened cam? But yeah, good thing you caught that. They will eat thoes cast gears in no time![]()
Yea it was one of those little details i missed and it would have been a big deal if i didnt find it... they also make a phenolic gear that im going to look into, i will be calling comp cams first thing monday to find out which gear they recommend
