So I have a 90 GT full stock suspension and full weight. Rebuilding the motor with a 347 stroker from coast high perfomance with one of there 800 hp internal engines. I have the trickflow top end kit, wtih a stage 2 cam from trickflow, 80mm maf, 75 mm TB from TFS, 30 # injectors, under drive pullies, 255lph fuel pump and mallory fuel pressure regulator. Car has 3.73 gears and will have upgraded 28 spline axles. I'm pretty sure the CHP block is stock deck and the heads I have are unmilled and can hande .600 of lift. Questions are, if I stick the cam in straight up, with I have PTV issues, also can I run 1.7 roller rockers instead of the 1.6's that come in the kit? Also, I know I need to run a solid lifter to check for pushrod length but would you know at least what size checker I would need, if not the actual length? I am running nitrous with this setup and am shooting for 11.5 quarter times on 275 drag radials. Any rwhp estimates and know with 75 or 100 hp shot is a good start?
thanks for all the support
V
V
