347 Build IN PROGRESS!!! Pics inside
Davin
1,353
Jacksonville, FL
FINALLY! I spent the last 2 days working on my 347 after getting my block back from the machine shop. This is so much fun..I'll have to wait till my next off cycle to finish her, but I'm off to a good start. The stroker kit I used was from CHP. I was pretty impressed with the quality. This is my first engine build and its going suprisingly smooth, I guess that's what happends when you take months to plan it! lol. I had to notch the cylinders myself to clear the rod bolts...I got a slick main support/windage tray from DSS Racing so that I could retail a stock oil pan (I decided that I wasn't sure it a support was needed but it could only help!). I included a couple pictures. I mocked up a pics with the AFR 185 heads and RPM II intake, I'll need a 1 " spacer to clear my valve covers, but I am psyched! ..can't wait to finish her!:D
Thanks, I'm stoked (and stroked) :D Had to get the spacer cause I just love the tall Ford Racing valve covers..The only thing I'm mildly worried about is the torque curve due to the extra inch in the intake. If I don't like it I'll just clean and paint the stock covers and use those. Since I already have the RR hood on, clearance shouldn't be a problem.
Vibe - ended up going with the 1 5/8 primary tubes on the LTs, I see what you meant about the D ports and the 1 5/8 primaries. I really didn't want to go bigger with the exhaust so I ended up grinding open the flanges and cleaning the welds..It's not perfect, but it should work, hopefully I didn't take too much off!
RIO - Yeah, there is actually an opening plate on the bottom of the upper (~1/8") that still needs attaching, otherwise, the rear would fit fine. The real challenge is the drop that the adapter puts on the TB, that's about 3/4" off.
Vibe: I wanna say its around 9.3:1; won't be the highest compression out there, but should be good for longevity.
PCV Oil Separator
Husky Mini General Purpose Filter from Home Depot - $11
Two 1/4" male fittings - $3
Not having to pay and extra $56 for a "Steeda" label - PRICELESS!!!
So glad there are people in the know her on Stangnet to pass on this great information...
BlackVert - been there man, wrenching while laying on a gravel driveway...then it starts to rain! A Garage makes all the difference..like your own personal BatCave :nice:
Thanks for the nice comments, I'll post some more pics when I get it in the car..I painted the engine compartment while it was out so it should look nice.
