347 Install (PICS INSIDE)
mustangt562
226
Long Beach
Here are some pics of the install with captions hope you enjoy.
oil cooler lines
oil cooler installed
trans cooler installed
fabed brackets for coolers
overflow guide cause the canton one would not fit right with a fluidyne radiator.
The completed modified canton overflow mounted.
Bottom modified canton overflow
engine bay
the magic box. the sand blaster :) makes every old nasty bracket better than new!!
Everything you need to fab anything you need!
Thanks bro
WhiteDevil said:
That looks sweet! I wish i could fab stuff up. Whats the combo on your 347. I have one that should be going in the car in a couple weeks.
CHP street fighter pro street 347, .509/.532 222/232 (112), AFR 185cc x 61cc, all forged internals, 10:1, main girdle, windage tray, MSD ignition/dizzy/wires/coil, fluidyne rad, canton overflow, ceramic bbk shorty headers, 3.73, 30lb squirt, 190 fuel pump, c&l true flow, 90mm lmaf, edelbrock performer intake, flowcooler highflow waterpump, romac 28oz balancer, underdriven crank pully, oil/tranny coolers, new ac pump/hoses/accumulator, 200amp alt, plx m-300 wideband o2 air/fuel monitor, autometer phantom oil temp/oil pressure/tranny temp/water temp, transgo shift kit, b&M deep tranny pan, 70mm tb, bbk intake spacer, high volume oil pump, magnaflow h-pipe with highflow cats, flowmasters, autopower 4 point, kirban adjustable fpr, subframe connectors, aluminum wire looms, aluminum driveshaft, tokico shocks, thats about all I can think of right now :)
