Allright First post!!!! I have read a lot of posts on here and I know that there is a vast amout of opinion on what kinda of injection setup to run on a 347 stroker, depending on compression and whatnot, what i am in the process of doing is a 347 stroker out of my stock 302 block, JE pistons, Eagle H beams, scat or eagle crank, roush or afrs, not sure what cam yet (still deciding between custom grind or off the shelf cam), prolly the edlebrock preformer RPM intake, 2.5" exhaust, no cats,,, it looks like most people are using stock rails, 24# injs, C&L MAF and 70mm TB and some sort of 30-34deg timing, . just wondering if a couple more guys with the 347 stroker steup could post what they are running and any advice, problems, experiences with different setups, looking for somewhere around 400-450 HP w/o super or turbos, putting this in my 89 vert, thanks
