351/408w stoker engine help
  • Thread starter Thread starter jk351w
  • Start date Start date May 30, 2007
jk351w
15
  • May 30, 2007
Hey I’m looking to buy a 351/408w stoker small block engine online. Preferably all forged internals, roller cam ready (if not, then flat tappet), CR around 10.5:1 w/61cc. Can anyone forward me to some reputable dealers? I’ve been searching online and I just would like some second opinions. Thanks in advance.
BigHairyMonkey
411
Houston (Bellaire) TX
May 30, 2007
  • May 30, 2007
look around your area first its always good to have a shop that is local do your build for you because if somethings ****s up, or your not satisfied with something you can always drop it off and have them fix it. imagine shipping a shortblock back and forth between states.. its a PITA.
buckwild880024
9
Pa
Jan 21, 2016
  • Jan 21, 2016
i currently have a 351w 30 over that i am looking to make some changes to and get more power out of. looking for was to get the most bang for my buck. getting a great deal on a stroker crank from a budy of mine. he bought it and is now changing to the cyote motor. some research i have done says... cks-w351ee crank and stock length rods should get me 408. i have the performer rmp cam/intake/ ect.
just trying to find out if just replacing the crank is going to work and if i change to the x303 cam am i going to have clearance issues
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 21, 2016
  • Jan 21, 2016
Don't know if that is a 4",3.85",3.5" stroke by the part number listed. If you are changing to a 4" stroke crank(which is for a 408) you'll need different rods and pistons(if changing from a 351). Also you need to machine the block for clearance. You also may need to change the flywheel/flexplate-balancer,depending on what that particular crank calls for. Is it 28oz Imbalance,neutral balanced,etc. The cam shouldn't have any ptv issues but that is independent to your heads,piston type,head gasket thickness,deck height,etc. You should always check the ptv clearance, valvetrain geometry,etc when making changes.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Jan 22, 2016
  • Jan 22, 2016
Please start a new post... You replied to a post from 2007
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
302 Engine build questions
  • Vulpes5.0
  • Apr 19, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2022
LEEDAY Boss
E
For Sale 1989 LX Notch 410ci 85mm turbo 8 pt cage 9" rear end
  • EightyNineFive
  • Aug 22, 2021
5K
Fox Body Mustangs For Sale (1979-93) Jun 18, 2022
Freakinstang
F
A
1987 408 Stroker comperssion
  • AnonymousIguana
  • Oct 2, 2018
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2018
a91what
