351 conversion kit
  • Thread starter Thread starter samuraichamploo
  • Start date Start date May 29, 2004
samuraichamploo
367
Beaumont, TX
May 29, 2004
  • May 29, 2004
351 windsor conversion kit question! PLEASE HELP!!!!!
Is there any place that sells a complete 302- 351w conversion kit?
all That i know of it needing would be a oilpan, oilpick, new headers (can u reuse H pipe? ) different flywheel, and different belt.
any info is much appreciated, especially links to where i can buy it all
samuraichamploo
367
Beaumont, TX
May 29, 2004
  • May 29, 2004
also, I have various people telling me that the headers I have WILL work with a 351..
If this isnt true, whats the CHEAPEST option for a set of headers that will work.
samuraichamploo
367
Beaumont, TX
May 29, 2004
  • May 29, 2004
plz plz plz, someone help a brotha out. I checked old posts, and no links are given.
Im looking to buy everything i need in a package type deal.
samuraichamploo
367
Beaumont, TX
May 29, 2004
  • May 29, 2004
hllon4whls
BANNED
2,567
Covington
May 29, 2004
  • May 29, 2004
Shorty headers will work on a 351 or a 302. If you use 302 headers on a 351, your exhaust has to be about 1.5 inches higher (longer) to make up the difference. Swap headers do that for you without modifying the exhaust. LT headers range in the 350-$500 range for 351 swap. Dont know why so much.
www.50resto.com has a lot of swap parts. You should request a catolog. Give those guys a call. They are super nice and may be able to offer a bracket kit. I looked in the catalog today and noticed some brackets. They are very cheap.
samuraichamploo
367
Beaumont, TX
May 29, 2004
  • May 29, 2004
thanks mandeville!
-nola
5.0 HOtrain
2,247
New Hampshire
May 30, 2004
  • May 30, 2004
Holcomb motorsports sells swap kits, as does kaufman motorsports.
stangracer79
226
grande prairie alberta canada
May 30, 2004
  • May 30, 2004
and you need to consider the stuff in this link when doing the swap!
http://www.fast351.com/tech/4cyl.htm
samuraichamploo
367
Beaumont, TX
May 30, 2004
  • May 30, 2004
i dont have a 4 cylinder....
i have a 302 right now
My main question would be this:
Can I, or Cant I reuse the stock ford shorty headers?????
stangracer79
226
May 30, 2004
#10
  • May 30, 2004
  • #10
just get swap headers like MAC:http://www.macperformance.com/store/category.cfm?SID=3&Category_ID=354
5.0 HOtrain
2,247
New Hampshire
May 30, 2004
#11
  • May 30, 2004
  • #11
WTF would you want to reuse the stock ones? If you cannot spring for new or used aftermarket headers you cannot swing the motor swap
SmockDoiley
1,591
San Diego, CA
May 30, 2004
#12
  • May 30, 2004
  • #12
I would say if you had aftermarket headers you could because it oly involves lengthening the H-pipe, but not if you are using stock headers. As for the swap, dont forget you need a new dizzy and intake too.
samuraichamploo
367
Beaumont, TX
May 30, 2004
#13
  • May 30, 2004
  • #13
I have some hooker long tube headers.
11sec87
161
ill
May 31, 2004
#14
  • May 31, 2004
  • #14
sounds like you have just enuff info to be dangerous!
have you looked at the intake side of life yet?
302 intakes dont work on a 351- then theres fueling issues, hood clearance depending on set up, distributor/gear, balancer flywheel,-dont jump into this unless you have the info- or lots of cash to waste.
samuraichamploo
367
Beaumont, TX
May 31, 2004
#15
  • May 31, 2004
  • #15
I already have a super victor intake and a holley 750 double pumper.
think its gonna fit?
11sec87
161
ill
May 31, 2004
#16
  • May 31, 2004
  • #16
if its for a 351w- not through a stock hood- if your still going to use the old parts, ill see you on ebay with whats left after you fire it up.
samuraichamploo
367
Beaumont, TX
May 31, 2004
#17
  • May 31, 2004
  • #17
under the hood i mean
mcmmotorsports
689
Danbury, CT
May 31, 2004
#18
  • May 31, 2004
  • #18
Great site
http://www.fast351.com/index.htm
SmockDoiley
1,591
San Diego, CA
May 31, 2004
#19
  • May 31, 2004
  • #19
Dude, I really think you are not qualified enough to do this swap. As for the headers, I would think they would get too close to the floor pans because the 351 is raising the height of them, but you can offset that by using the hood clearance engine mounts that lower that engine an inch to clear the hood. Again, the intake must be for a 351. If your intake is then it will fit but probably not under a stock hood. Thats too much intake for that engine anyways. Your going to have a horrible combo with the way things are going. What ever happened to your engine with the bent pushrods?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 31, 2004
#20
  • May 31, 2004
  • #20
salty - you can use a shorty header - it will bolt on the 351 head and the collector will sit an area that's fine. But because the deck height of the 351 is a little over an inch taller than a 302, the place the collector sits will be a little over an inch higher -- which means your old h-pipe won't work. So - use the stock style shorty header, and your h-pipe will have to be altered.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
