351, KOOKS headers, what mid-pipe?
BlackVert
5,589
9
98
Bethesda, MD
I kindof want a 3" MAC pro chamber (PN 3395) and 2 sets of high flowing mufflers, but I don't know if the mid-pipe will match up to the midpipe.
What do you 94/95 guys with 351s and KOOKS long tubes have for the rest of your exhaust setup?
I don't know of a mass produced mid pipe for our combination. I had a local shop weld flanges on the collectors and build a 3 inch X pipe to fit between my current exhaust set up and the flanges on the collector.
Works great and cost about $250.00.
I know Mike (Low50) purchased his X pipe from Kooks. I'm not sure how he put it all together though.
The Kooks headers use a slip on connector, so I just went with the Kooks universal x-pipe. It's a cut-to-fit piece and it eventually fits very well, after the cutting and welding. I love the slip connectors, it only takes a minute or two to remove the x-pipe.
Here's a pic of how mine turned out.
cbarr300 said:
hmm...those slip connectors seem pretty trick. How much did the headers and universal x run you?...if you don't mind my asking that is.
And also, are the kook lts coated or would that need to be done seperately?
jet-hot coating is $275 extra. they sell stainless steel ones though for about $250 extra.
the kooks x-pipe is $245. :notnice:
www-completeexhaust-com (replace the dashes with dots) sells magnaflow 3" stainless steel x-pipe stubs for $85 (#10792). they also have a flo-pro 3" x-pipe stub for $49 (#X300). maybe i'll go with one of those. i also want the flo-pro twister mufflers.
