351 Roller Block Questions
  • Thread starter Thread starter rhyno9
  • Start date Start date Feb 8, 2006
rhyno9
209
Oswego Illinnoying
Feb 8, 2006
  • Feb 8, 2006
I picked up a 351 roller short block last night. It already had a roller cam installed and was supposedly the stock cam for that engine.
I recall reading somewhere that even though they were roller compatible ford never installed roller cams in the 351w?
Does anybody really know???
Any idea on what I can do to figure out what cam it really is if it's not OE?
Does the type (1 piece or 2 piece) of rear main seal make a difference in the oil pan that I use?
Thanks
RV
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Feb 8, 2006
  • Feb 8, 2006
Thanks
RV
Not a roller block but I used my 69' oil pan on my 89 block with a 1 pc rear seal. No issues. Just has to be a pan from a 351.
As a side note, I also used a 65' 289 timing cover and harmonic balancer to retain my 65 water pump and pulleys.
D
D.Hearne
11,730
south louisiana
Feb 8, 2006
  • Feb 8, 2006
The roller 351 had the F4TE hyd roller. Same cam used in the 94-up pickup and Van 5.0 and the later 96-2001 Explorer/Mountaineer. Good street cam when used with 1.7 rockers. Lift with the 1.7's is .450/.473 ( int/exh) duration is one step below the GT/HO 5.0 cam at 256/266 degrees (advertised) I've got one in my "spare" 5.0 in my 89 Ranger, works great with either an automatic or 4 speed and a 600 Holley 4 bbl carb.
rhyno9
209
Oswego Illinnoying
Feb 8, 2006
  • Feb 8, 2006
Thanks for the help guys.
RV
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
