Roush 351 streetbeast
97predator
302
va beach
got some questions for yall. i read up on the S351 and thought it was aa abda#$ car. is it possible to shoehorn somehting like this into a 99-up mustang? http://www.automotix.com/engines_by...351WHOLB-1.html
if so, how would one go about setting it up with EFI. is the setup used by Saleen a custom manufacture for their use? or are there kits for this? then, i bet a twin turbo setup would just be sick on somehting like that.
link does not work.
bummer. it was a 351 crate engine. it was 1800 for the long block. am i write in this, that the 5.0 heads fit, but that the head bolt holes just would need to be drilled out to the 351 size of 7/16"? then go superchargeed, i think that would be a mean street car. obvi :hail2: usly the S-351 is.
You can do the conversion. You have to change the K-member, wire harness, tranny, cooling system,and modify the fuel system just to install the windsor. It is really cheaper to just buy a used S351 than to do the conversion unless you have the parts to do the swap lying around. You could buy a wrecked 94-5 GT and you would get alot of the parts needed.
i love the saleen look. how much would a s351 set me back. at the top of the summer i will be in a position to buy. i really want the displacement of the s351, and as said before, the style is incredible. thanks.
