Don 95Vert
Here's my little 393 that just went in my SN-95...
Ditto what everyone else said, except the only really practical way to convert a non-roller block to roller is with the $400 lifters. If you use a spider on an early block you need a small base circle cam.
The Trickflow intake just barely clears my "R" hood.
You can get a distributor from a '96 5.8 van from Autozone for $50 and it has the right gear on it already.
The 302 timing cover and accessory pulleys will bolt right up, as will the water pump. Jegs has the conversion oil pans cheap.
Remember this too - if you put 302 parts (like intake etc.) on a 351, you'll get 302 power out of it.
