351 WINDSOR HEADS ON A 302, possible?
1BADLXCOUPE
23
florida
ok, just a thought, 351 Windsor heads..What type of modification(s) is needed to make them compatible with 5.0LTR retaining all factory features..??also will the stock valvetrain "roller rockers, etc." work with the 351 style geomotry??any information will be helpful and appreciated-
korey young
jerryD
1,061
Gladstone, MO
the heads will bolt up no prob, you just have to get what is called "head bolt bushings." these things will take up the slack of the 1/2" size bolt holes that the 351 takes cause a 302 uses 7/16 bolts. they just go into the head before you put the bolts in. sometimes they kinda have to be pressed in, i just let the bolt press it in while tightening them up.
for the valve train, that depends on what heads you are using, stock pedastal style or stud mount. and you will then also have to check for proper pushrod length as well.
