351c hp estimate
  • Thread starter Thread starter bswor
  • Start date Start date Jul 14, 2004
bswor
65
  • Jul 14, 2004
Looking for an estimate or dyno results from people with the same setup as me. Running a 1972 H.O. 351c block, 351m 2v heads (guessing stock rebuilt heads, all this was in the car when i got it), edelbrock performer intake, 650 edelbrock carb, super comp headers, dual exhaust, c-4 tranny, 2.89 or 3.0 8" rear.
Thanks guys.
SadbutTrue
2,391
Thousand Oaks, California
Jul 14, 2004
  • Jul 14, 2004
compression? stock cam? any little stuff done to it like ignition, filter, porting, etc?
bswor
65
  • Jul 15, 2004
I'm not real certain but im going to say stock cam, i can run 87 octane no problem. Petronix, no porting that i know of, and filter (just regular round one? lol)
66coupe306
32
  • Jul 15, 2004
Its hard to say as a Cleveland mildly built can make alot of HP. Ex. the stock 2bbl heads come with 2.05 intake valves. Look at aftermarket heads, most are not that big. The stock intake and exhaust runners are pretty good except for the water jacket hump in the exhaust port, although I think that is more of a concern with 4bbl heads. Another thing with a cleveland, in 72 they came retarded at the chain 2 degree's, motorsport sells and indexed timing set that allows you to advance it back to make more power. Even with flat tops, it is propably making approx. 10:1 compression. It sounds to me, someone swapped in a production cleveland, so estimating conservatively, you propably have 250 hp. Now, that said, pump in a nice mechanical flat tappet cam, ditch the pertronix for a real ignition, advance the timing, either port your heads and match to a good intake or opt for 4bbl quench heads or 2bbl austrailian heads and then you could end up with a 450-500 hp motor. Mine makes 628.9 (dynoed) with a solid roller cam, spooned quench heads, svo intake stock balanced lower end w/ flat tops and some oil system work. These can be cranking motors.
bswor
65
  • Jul 15, 2004
Ok thats exactly what my guess was, around 250hp. Torque would be around 300? Sounds like you built a beast of a motor!
66coupe306
32
  • Jul 15, 2004
I don't know, 300 ft lbs sounds high, you don't have a diesel!
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
T
SOLD 1979 Ford Mustang Cobra Hatchback 302 C4 Modified
  • toasterboy1
  • Nov 15, 2024
2K
Fox Body Mustangs For Sale (1979-93) Dec 20, 2025
toasterboy1
T
