351c ?
HHStang said:
I thought you could tell by the air filter cover... :)
Well you CAN tell by the air cleaner cover whether or not the cover is a "2V" or "4V" item or not, but alot can happen to the engine under it in 30-something years. Or in simpler terms, what's on the cover, doesn't guarantee that what's under it is what's on that sticker. Both engines used the same aircleaner assembly in many cases. 2V means it's a 2 Venturi carburetor or barrel, 4V means it's a 4 Venturi carb. The Venturi is the section of the throttle bore that necks down to increase the air velocity and increase that signal to the Booster Venturi to pull the fuel from the bowls. The Booster is the round thing hanging out over the throttle bore.
look on the left hand side of the head, in the top corner.....
sorry man- I was kidding...
D.Hearne said:
Well you CAN tell by the air cleaner cover whether or not the cover is a "2V" or "4V" item or not, but alot can happen to the engine under it in 30-something years. Or in simpler terms, what's on the cover, doesn't guarantee that what's under it is what's on that sticker. Both engines used the same aircleaner assembly in many cases. 2V means it's a 2 Venturi carburetor or barrel, 4V means it's a 4 Venturi carb. The Venturi is the section of the throttle bore that necks down to increase the air velocity and increase that signal to the Booster Venturi to pull the fuel from the bowls. The Booster is the round thing hanging out over the throttle bore.Well you CAN tell by the air cleaner cover whether or not the cover is a "2V" or "4V" item or not, but alot can happen to the engine under it in 30-something years. Or in simpler terms, what's on the cover, doesn't guarantee that what's under it is what's on that sticker. Both engines used the same aircleaner assembly in many cases. 2V means it's a 2 Venturi carburetor or barrel, 4V means it's a 4 Venturi carb. The Venturi is the section of the throttle bore that necks down to increase the air velocity and increase that signal to the Booster Venturi to pull the fuel from the bowls. The Booster is the round thing hanging out over the throttle boreWell you CAN tell by the air cleaner cover whether or not the cover is a "2V" or "4V" item or not, but alot can happen to the engine under it in 30-something years. Or in simpler terms, what's on the cover, doesn't guarantee that what's under it is what's on that sticker. Both engines used the same aircleaner assembly in many cases. 2V means it's a 2 Venturi carburetor or barrel, 4V means it's a 4 Venturi carb. The Venturi is the section of the throttle bore that necks down to increase the air velocity and increase that signal to the Booster Venturi to pull the fuel from the bowls. The Booster is the round thing hanging out over the throttle bore
the 4V heads are better for high RPM, while the 2V are better for the street. people will tell you that 4V is fine for the street, but it is a little soggy in the lower RPMs. IMO my 2V motor will run circles around my 4V on the street. racing, thats another story..... :)
From the dyno numbers I've seen, 4V must only seem soggy in the bottom end due to the incredible top end. It's just so much stronger in the top that the bottom doesn't seem as good. In reality there's very little difference in the bottom between 2V and 4V and I've seen some 4V builds that had a better bottom as well as the top.
But hey, buy some 2V Aussie 302C heads if you want. The more Clevelands running here in the US the better IMO.
:) :nice:
