351w Injector Help
Dave34
63
im building a 351w with 11:1 compression good flowing heads good intake but i need to know what size fuel pump and injectors and i might decide to run ethanol so what size if i decided to run ethanol
What tuning device? Staying n/a only? If so some 42's would be enough and a 255-340lph pump would support it without a problem. Actually a 255 supports something like 700hp n/a (gas). Even running meth you're still fine. IMO
The AFM PMS is a descent set up. You could go mega or micro squirt or another EFI standalone system like FAST,Holley,Pro-m,etc. The main reason I asked was concerned you weren't going to use any. With your purposed build you could get by with a good dyno tuned chip also.
Depending on the heads,intake,and cam etc you're looking at anywhere from 400-550 fwhp. To achieve the high end of that range it's going to take at least a 205cc head,very healthy cam(I'd assume at least 240*dur @ .050),single plane EFI intake(super Vic),1 3/4"-1 7/8" long tubes and spin that thing to around 7k rpm. If you're going with a milder version and want to save a few bucks just get a chip done. If it's at least that aggressive or more I'd look into other tuning options and maybe step up to 60# inj. Don't forget to get aftermarket fuel rails and lines also. I'd just go with a quality fuel system kit from either aeromotive or Glenn's performance. They have quality components and will supply your fuel demands even if you add more power down the road.
