351W intake question
What are you able to interchange from a 5.0 intake setup and a 5.8 intake setup??? I know that the fuel rails will be farther apart and the lower intakes won't interchange, but what about the uppers???
Can you bolt a 5.0 upper to a 5.8 lower??? I thought I heard somewhere that the bolts line up different.
Oh, and does it make a difference if it's a truck 5.8 and a car 5.0 <-not going in a Mustang, just a general engine question.
Thanks in advance
If you use a stock 351w truck lower....it uses the same pattern as some aftermarket intakes,but is completely different pattern than the stock mustang.
Unless you get a 351w Lightning lower, then you can use a GT40 or Cobra upper, maybe an explorer upper(not sure about that last one)
