351W intake
  • Thread starter Thread starter Stopsign32v
  • Start date Start date May 19, 2008
1 of 2 Next Last
Stopsign32v
394
Gville, SC
May 19, 2008
  • May 19, 2008
What are the options for a 351W EFI intake?
samickguy15
404
Delavan, IL
May 19, 2008
  • May 19, 2008
As always, a search would have been worth while...
Your options are truck intake, TF Box R, Performance Products AKA Edelbrock knock off, and Edelbrock. I think Holley has one too... You can go with a carb style EFI intake also...Spyder I think is the name...
Stopsign32v
394
Gville, SC
May 19, 2008
  • May 19, 2008
I have searched damn near every "351 swap" thread there is.
88mouse
630
Mooresville nc
May 19, 2008
  • May 19, 2008
Also there is one that they used on the 1 gen L's you can use the gt40 upper or the cobra. Same as the 95 cobra r.
Stopsign32v
394
Gville, SC
May 19, 2008
  • May 19, 2008
No I need a big intake. I'm thinking about the Super Spyder with a 90mm TB. Just gotta figure out how that would do for a street car.
vristang
4,933
101
124
Seattle
May 19, 2008
  • May 19, 2008
The spyder will be just fine on a street car... assuming the heads and cam are appropriately matched...
88mouse
630
Mooresville nc
May 19, 2008
  • May 19, 2008
Why do you need one so big for?
Stopsign32v
394
Gville, SC
May 19, 2008
  • May 19, 2008
The Spyder is no longer made. Now they only have the Super Spyder which I wonder if it would be too big or not?
vristang
4,933
101
124
Seattle
May 19, 2008
  • May 19, 2008
Where did you hear that the spyder was no longer in production?
I'm planning to run one in my 408w......
The thing is, with proper cam and head selection, the total package should work just fine.
What are you considering for heads and cam?
jason
Stopsign32v
394
Gville, SC
May 19, 2008
#10
  • May 19, 2008
  • #10
jason
Call CHP there is no more Spyder intake. However I am thinking about making me one with a Victor JR carb lower and a Spyder intake elbow.
Heads I am going to run Twisted Wedge CNC 205s and the cam will be custom. All I need to do is figure out which intake would be best for what I want.
vristang
4,933
101
124
Seattle
May 19, 2008
#11
  • May 19, 2008
  • #11
Well,
If you are getting a custom cam, then let the cam designer decide what intake will work best with your setup.
Don't limit the cam designer to some parts you selected based on internet 'opinions'....
Let him optimize your setup and make recommendations based on your goals/buildsheet.
Have you decided who you want to go with?
squeak93
2,342
414
164
Joplin, Missouri
May 20, 2008
#12
  • May 20, 2008
  • #12
I am running a eddy super vic jr efi with a spyder elbow. Custom comp cam.. I can tell u that the car pulls like hell all the way to 7k. It doesn't however have a ton of torque till u hit 3700 or so. not such a big prob for me as I have a 3500 stall and a 4r70 gearset in the trans. So it matches my combo pretty good.
I can tell u my efi spyder elbow quality is crap compared to the similar eddy pieces that are just now becomming avail. i actually have to get my elbow re machined as it is warped (from the factory) on the gasket suface that meets the lower.
Just my 2 cents.
BTW the eddy is already matched perfectly to a fel pro 1250 intake as were my heads so that was a very easy install. The efi spyder elbow fits up to a 90 mm tb, but if u use a 75, trim off the round part of the gaskets that is not needed, ask me how i know....
Stopsign32v
394
Gville, SC
May 20, 2008
#13
  • May 20, 2008
  • #13
Does Edelbrock make an Elbow so I don't have to buy a pos CHP product?
a885.0
20+ Year Stangneter
Feb 2, 2004
78
CT
May 20, 2008
#14
  • May 20, 2008
  • #14
Yes edelbrock has 3-elbows available, part#s 3847(ultra low profile)3848(low profile),and 3849. I run the 3849 on my 410w along with a edelbrock super vic. intake. We did have to modify it to fit under my 3'' hood however. We took about a 1-1/2'' out of it to fit under the hood. here is a pic.
squeak93
2,342
414
164
Joplin, Missouri
May 21, 2008
#15
  • May 21, 2008
  • #15
yes, all three should be avail by now. When I put mine together 2 months ago, I couldn't get my hands on an eddy piece to save my life. I can tell u that with the chp I barely clear with a 3.5 inch cobra r hood. The eddy piece (the middle one) has to have a 1 inch spacer if ur using eddy rails to make the tb clear.
Good luck.
fords2fast4u
1,426
Mission Viejo, CA
May 21, 2008
#16
  • May 21, 2008
  • #16
http://www.musclemustangfastfords.com/tech/mmfp_0610_mustang_intake_manifolds/index.html
found that and thought of this thread. Nothing wrong with the spider I'm sure, but thought I'd throw this out there.
I'm going with the TFS R long runner version myself...
Stopsign32v
394
Gville, SC
May 21, 2008
#17
  • May 21, 2008
  • #17
I am wanting to fit the intake under a 1.5" hood. More than likely I would have to go with the 3847 (pic below) to fit under the hood. However it looks like it would have MAJOR issues with even airflow to the runners. HOWEVER I am going to be using the Zex nitrous plate so that will add 1"-1.5" to it. Hmmmm Wonder how I could figure out if it would work short of buying the parts and sending them back if they don't fit.
Stopsign32v
394
Gville, SC
May 21, 2008
#18
  • May 21, 2008
  • #18
Yes I am definately thinking about running a ported TFS box intake. I'd have to see if NX would put a spray bar in the metal spacer between the lower and upper though.
a885.0
20+ Year Stangneter
Feb 2, 2004
78
CT
May 22, 2008
#19
  • May 22, 2008
  • #19
Thats what I did, I bought a 3847 with a 1'' carb spacer (from summit) to test fit
and didnt like it at all, it has a real long neck on it and it put the throttle body almost
into the shock tower. So I packed it up and sent it right back to summit(they are real good about returns).
enyawix
507
May 22, 2008
#20
  • May 22, 2008
  • #20
You missed the lightning gt40 intake! I had mine ported and powder coated.
1 of 2 Next Last
351W/5.8 EFI intake manifolds fading away...
  • Ryno5150
  • Jan 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
nickyb
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
W
Need help! 1989 mustang
  • wickedzach487
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
AeroCoupe
E
Mustang Forever
  • ELP1
  • Apr 11, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 11, 2026
ELP1
E
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
