351w intakes
unrealmach1
89
Detroit, MI
I read somewhere a discussion on shakers and someone was saying the performer rpm intake moved the carb back further in the engine compartment. Is this true? I know it is taller than stock. The problem I have is the shaker on my car seems to sit back 2-3" too far to come through the original hood. I don't have the original intake to compare. I am running a roller 351w block in a 69 mustang. I purchased a shaker from ford gt in au a few year ago. I think is for a 351c. I also heard the 351w shaker moves the shaker forward? Anyone have any knowlege on this issue??
One of the basics of intake manifold design is to make the runners as equal in length as possible. This being the case, I'd be surprised if the manifolds from different manufacturers varied by more than a few thousandths of an inch.
Now the height of the 351W vs. the 351C might have been a bit different, which would account for a different air cleaner base.
If you're looking for a factory equivalent to the RPM intakes, Ford made them in the late 60's and early 70's. The casting numbers are C9OX, these are aluminum high rise dual plane's. And there were at least two versions with the same prefix but different suffix for the 351W.
This may be the design goal of the aftermarket, by not OEM Ford. The OEM Ford 4 barrel intake has the carb about a half inch farther forward than most if not all aftermarket intakes. In addition, the Windsor shaker moves the top even more forward. If you try to bolt up the factory 351W intake to shaker bracket you will see that it doesn't line up. I have tried it with both the Performer and the Torker II. With the Toker II and a factory Windsor shaker base, the hood opening barely clears the Shaker at the back, and in fact it rubs slightly as you open/shut the hood.
The Cleveland shaker uses a totally different base than the Windsor. All of the other Mustang shakers use the 428 base with adapters tack welded to position the shaker as required (both fwd and up on the Windsor and Boss 302, and presumabley just up on the 390; I've never seen a factory 390 shaker).
