D deion82 Founding Member Sep 14, 2002 187 0 0 minnesota Sep 19, 2004 #1 Sep 19, 2004 #1 A guy told me that a hyd. roller cam from a 302 will fit the 351w non roller block utilizing a retro kit (installing the spyder bar) with stock ford hyd roller lifters. Is this true I thought a special lifter was required? Thanks
Rick 91GT Mustang Master Nov 29, 1999 9,692 95 99 PA Sep 19, 2004 #2 Sep 19, 2004 #2 Yes a 302 cam will fit in the 351. However to use a stock lifter bar and stock lifter you need to run a SMALL BASE CIRCLE cam (not the stock cam) To run a STOCK cam you need to buy the linked bar lifters, which IMO is a better way to go.
D deion82 Founding Member Sep 14, 2002 187 0 0 minnesota Sep 20, 2004 #3 Sep 20, 2004 #3 Thanks, that's what I thought that the linked bar lifters were needed. A stock hyd roller 302 cam is a .950 base? What would the small base cam be?
