Is it possible to make 425 or more HP from a stock '69 351w without stroking it? If so, what combination of parts would you guys use? The car will be used on the street so low end torque will be needed. Thanks.
Mosse said:"Fuelpump block off plate"
How about, if I may capture part of this thread, what about with stock heads, or cleaned up stock heads?
wickedmach1 said:Is it possible to make 425 or more HP from a stock '69 351w without stroking it? If so, what combination of parts would you guys use? The car will be used on the street so low end torque will be needed. Thanks.
