351w vs. 347 stroker
  • Thread starter Thread starter 9 Deuce GT
  • Start date Start date Nov 15, 2004
9
9 Deuce GT
550
Geneva, NY
Nov 15, 2004
  • Nov 15, 2004
I have been doing a lot of research about the 351w swap I am in the process of building. I have really been comparing the 347 vs. the 351w builds many of you guys/girls have been doing. My question is: I see a lot of power being made by the 347 setups (400-425 rwhp). I have not seen many of these types of results by a 351-357 build up. I am wondering why? Obviously most guys going the Windsor route are build their own strokers, but I just could not pass up the sweet deal I got on my 358w. (40 over Jasper rebuild, complete from air cleaner to rusty stock,exhaust) I don't see a real difference in cubes between the two, but it just seems that most 302 based strokers a kicking serious ass, and most 351w swaps are making an average of 325-375 at the crank. Whats the deal?
hllon4whls
BANNED
2,567
Covington
Nov 15, 2004
  • Nov 15, 2004
Built with similar quality and design parts, the output is virtually the same. Now if you compare a lightweight 347 crank with light rods, etc to a stock crank, stock rod forged piston 351, then that is not apples to apples. I make somewhere around 425 to the tires with my 351. Stock crank, forged pistons. Better cam and converter, streetable combo with same times.
EMW150
2,020
Roaring Spring,PA
Nov 15, 2004
  • Nov 15, 2004
I think the only real advantage to a 347 over a 351 is recip weight. Set a 347 piston beside a 351 piston. Big weight difference there alone. A 347 piston is very short to compensate for the extra stroke. That's great for making power but not great for longevity due to increased piston rock.
illwood
636
Worcester, MA
Nov 15, 2004
  • Nov 15, 2004
With a 351W you have the potential to stroke it to get some serious cubes (408 or more) that can equal some serious power, but it's gonna cost you in terms of weight (block is supposed to weigh around 100lbs more than a 302) and the taller deck height (mandatory hood swap).
Personally, I had wanted to run a built up 393W in my '94 GT, but I have changed my mind to run a 347 for several reasons:
1. I want to autocross this car and increasing front end weight won't help cornering (I'm already planning on a tubular k-member and aluminum heads).
2. I like the idea of a "sleeper" GT and I don't want it to look too different from factory (other than some 17x9 Cobra R's) by a cowl hood (tho i think it looks cool in its own respect)
3. (I know I'm gonna get some flack for this one) As this car is my daily driver (15+K miles/year) and I don't have unlimited income, I'd still like to have lots more power than I need but not be too much worse off at the pump. Yeah, I know I could just do an s/c, t/c, or giggle gas, and get some mileage, but I'm a naturally aspirated kinda guy. Since I can't run slicks on the street (legally) I wan't to chirp 3rd & 4th, but I don't want to have so much power that I'm constantly spinning them.
Sorry for going OT a bit, but just wanted to give you my perspective.
It all comes down to what is your plan for your mustang. Straight line? Corner carver? Knowing what your goal is helps decisions on the way and prevents you from getting disgusted with the project because you could wind up spending more than you want on things you don't "need".
9
9 Deuce GT
550
Geneva, NY
Nov 15, 2004
  • Nov 15, 2004
I guess I am wondering if the kinds of #'s 347's are making can be made with a 351w build? The reason I ask, is becuase I don't see a whole lot of guys doing it with a 351w. Most 351w combos you see are just a budget build, (nothing wrong with that, kind of what I'm doing), but I would like to know if the potential is there.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 15, 2004
  • Nov 15, 2004
what are the 331 strokers doing , I am probably going this route in the future ....
EMW150
2,020
Roaring Spring,PA
Nov 15, 2004
  • Nov 15, 2004
It can be done definately. Look at NMRA Hot Street class. Cory Roth is running 9 teens with a 358. That's a full on drag car with about every chassis trick available and running high compression with a huge solid roller cam but it can be done. A little milder build for the street would probably be somewhere around what the 347s are putting down give or take. With a 351 block though you get more strength but a little more weight on the nose too.
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
T
New Guy from Southeast Missouri
  • tcooke11
  • Jan 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 17, 2026
TomcatPC
J
Fox body - godzilla, coyote, or 408w stroker - Best route for budget build?
  • jaygee15
  • Jan 27, 2025
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2025
2000xp8
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
