373's and et's
cronin49
Banned
Aug 12, 2003
432
SC
Hey all, I just read in MM&FF that when you step up from the stock 327's to 373's you will shave off 2 to 3 tenths in the 1/4 mile. They say this is equal to about 40 HP. We all know that changing gear ratio does not increase HP, this is due more to torque multiplication. It makes sense to me, because the 2 people I know who installed superchargers gained around 110 - 120 HP, and dropped about 1 second, maybe a little more from their et's., going from 14.00 to 12.8 - 13.00. What do you all think about this bit of information? :nice: :notnice:
More gear equal's less traction :notnice: .Wich is the reason that some run even worse then they did with stock gears.Stickier tires will deffinatly help once you up grade gears :D .But if you lower the air pressure in the stock tires a bit,and a little clutch play,you can run some good times.
I ran 14.1's @ 101mph with stock 3.27',and with the 3.73's i ran 13.7 @ 103mph,on stock goodyears. :)
Great! You shaved 4 tenths off with the 373's! This only reinforces what my original post said, and then some. MM&FF is pretty much straight on almost all the time with their info. :nice:
So can you expect similar results with 4.10's? How much difference are we talking in terms of e.t. difference between the 3.73s and the 4.10's. More than 1 tenth? More than 2 tenths? Or hardly anything?
To original poster, what month MMFF was that? Recent?
one problem I have with change to 373s or 410s is that you trap in 4th.. and on stock gears you trap in 3rd.. this is why im keeping my stock gears in my auto..
The newest one, Oct. 2004. In a letter that starts on page 42 and ends on page 44. Its in the " Ask Bernie, Yo ken! section.
I did a little math, and I come up with a drop of 1 to 1.5 sec. going from 373's to 410's. Traction my negate this gain though, as Launching with 410's is more difficult then with 373's, at least on stock tires, Plus you got to shift into 4th at about 86 mph with 410's, I think this is too slow. At least with 373's, you can get up to about 95 mph or so before banging 4th and trap out at about 103mph. Everything else being stock.
