well, i installed my 3g alt and i am charging up good but my belt is now squealling. my set up before the 3g alt install was no smog or a/c and i did nothave the tension pulley on and it did not squeak. i have underdrive pulleys too. i got the 3g off a 95 taurus and the pulley looked about the same size of the underdrive pulley on the stock alt so i did not change it.
i thoiught i could put the tensioner pulley back on but i think it might be bad. it will not budge. how do i tell if the tensioner pulley is bad?i searched the forum but i was confused
i can't figure out how to get the pulley to adjust to a different height. also, i was thinking i might need to put the underdrive pulley on the 3g since it did not squeal with the old alt but it is super hard to take off. anybody have any luck taking this pulley off and how did you do it?
what do you guys think i can do to get my belt to stop squealling? any thoughts on this would be greatly apreciated as this 3g install is taking way too long.
i can't figure out how to get the pulley to adjust to a different height. also, i was thinking i might need to put the underdrive pulley on the 3g since it did not squeal with the old alt but it is super hard to take off. anybody have any luck taking this pulley off and how did you do it? what do you guys think i can do to get my belt to stop squealling? any thoughts on this would be greatly apreciated as this 3g install is taking way too long.
