For the battery cable, I got a 10' cable (4 AWG) at the local parts store - it is a generic one with eyelets on each end. Do note that this was for my 94.
On the fox, I used the stereo wire - I like that stuff better. The cost is about a push.
Jrichker has an outstanding post outlining all the parts needed, with part numbers, etc. I followed it to a tee (and added some heatshrink that was huge enough for the cables). If you follow his write-up and do the ground upgrade (which is a 'should-do'), you can use a battery cable instead.
Good luck.
