3G alt. wiring question?
One can get the 4 AWG online (Parts Express is where I got mine) or one can use a battery cable from the parts store. I have done each - the stereo cable online had a much finer wire strand/winding than the battery cable. Both worked well but the stereo cable is more mallable.
Good luck.
For the battery cable, I got a 10' cable (4 AWG) at the local parts store - it is a generic one with eyelets on each end. Do note that this was for my 94.
On the fox, I used the stereo wire - I like that stuff better. The cost is about a push.
Jrichker has an outstanding post outlining all the parts needed, with part numbers, etc. I followed it to a tee (and added some heatshrink that was huge enough for the cables). If you follow his write-up and do the ground upgrade (which is a 'should-do'), you can use a battery cable instead.
Good luck.
