3G alternator application
gregsmy
30
I was wanting to know if anybody has used the 3G from a late model Taurus (90-94)? It is supposed to be a 130amp unit but I dont know how it will fit on a 5.0. The back connections are a little different but it seem to be a lot cheaper than the 94-95 Mustangs. I did a search but it seems that most of the hits where on the Taurus electric fan.
I used one on my 90 GT and it works however the stud where you mount the 4ga wire is at the bottom side of the alt. It makes it impossible to mount the 4 ga wire. I have to see if the alt can be clocked by removing the bolts in the back and rotated.
I see that now that I look closer at the back of the alternator in a picture. Was there any clearance around the block for the wiring? Did you attach the wires and then mount the alternator? I would sure like to find out if you could take the screws out and turn in.
