Electrical No charge from 3g alternator
BigShowJoe
South Carolina
I have been scratching my head (or more like beating it against the wall) on this. I upgraded to a 3g 130amp alternator and have never been able to get it to charge.
1991 LX 5.0
4gauge power wire from alternator directly to positive terminal on the battery (I've tried connecting it to both the positive side of the solenoid and directly to the battery).
D Plug:
Constant 12v on the yellow wire.
12v on the green/red wire with the ignition on and a slight drop to ~11.6 with the engine running.
White wire looped from the D plug to the stator plug.
With the engine off, the battery is reading 12v. With the engine running, still the same 12v.
If I disconnect the 4gauge power wire and test voltage directly at the back of the alternator with the engine running, it reads from 28 to 35 volts but as soon as that is connected back to the battery, only 12 volts.
What can stop the alternator from outputting voltage when everything is connected as it should be?
Did you follow the 3g swap instructions in the forum here? Its been a while since I've done mine but I do remember deleting the two small 10 gauge wires and I added a mega fuse.
I don't know why but the how to for that is not coming up anymore???
Maybe some cookie counter can fix it?
I am wired exactly like the diagram below. If I remove the red wire from the battery the alternator is putting out 28-35 volts. With everything connected, I never see more than 12 volts.
Be careful with those voltage spikes...you could possibly cause damage to some of the electronics.
Yeah it was just a 5 second test to prove the alternator was putting out voltage. I just can't understand why it's not when everything is connected.
Have you tried a different ignition on source for you green wire? Read that if the dummy light burns out it kills the voltage to signal the alternator. I ran into a similar problem when I converted to a digital dash cluster. There was not voltage on the green wire. Tapped into a different wire and magically 14+ while running.
Reactions: Mcmahst
