3g Swap Problem..need Help
BKM48198
377
27
49
Ypsilanti, Michigan
I did a 3G alt. swap using the OE wiring and when I turn the defroster on or have it in the middle switch ( heat & defrost) my AC kicks in. I spliced the single wire into the unused wiring harness using the wire that looks like it is either white /black or yellow/black...is that the correct wire or should it be connected to the middle wire on the D-plug that is used?
Do not reuse your existing power wires. You need a dedicated 4 gauge wire from the alternator power post to the + side of the starter solenoid with a 125 inline amp. The only wire to re use off that plug is the stator wire. You will use the D shaped regulator plug and wires. Do a search in the technical archives and you will find a write up
I ran 4 gauge for power, only reused the D-Plug
