  • SN95 4.6L Mustang Tech
4:10 install Questions
  • Thread starter Thread starter smokin'Red35th
  • Start date Start date May 18, 2004
smokin'Red35th
493
Las Vegas, NV
May 18, 2004
  • May 18, 2004
I posted this in race tech but thought i would cover 4.6 to get more of a response.
I'm about to purchase some 4:10 gears. Does anyone have specific brand reccomendations? what should i pay for install? what do i need to make sure i have prior to install? (extra items) I appreciate all the help!
Oh yea, I am getting 4:10s cuz I think thats a happy medium between not enough gear and too much. What are your thoughts on this philosophy? Thanks again!
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
May 18, 2004
  • May 18, 2004
FRPP is the highly popular brand. I also recommend even OEM Ford.
Typical gear install takes about 4-6hrs. Depending on who's doing it so you can guage prices from there based on hourly charges.
Prior to the install, you need to make sure you have the gear set. Inside, there should be a ring gear, pinion gear, pinion nut, crush sleeve, and some shims. In addition to this, you'll need 2qts. of rear differential fluid and a 4oz. bottle of friction modifier.
As for 4.10's, I think they're a good gear ratio, especially for n/a cars. If you're going boosted in the future, you might want to consider something less, like 3.73's. Just my opinion.
smokin'Red35th
493
Las Vegas, NV
May 18, 2004
  • May 18, 2004
great, thanks!
So far this is the list of what I need for install:
*4.10 Gears
*2 Qts of 75W140 rear differential fluid
*4oz bottle of friction modifier
also, someone said something about new master bearing kits for cars with higher mileage. I have close to 79,000 miles on my 99 so when i change gears do i need to purchase the master bearing kit too? I just want to make sure i got everything i need when i go to install.
bowens99GT
655
On some dirt road in Arkansas
May 18, 2004
  • May 18, 2004
Motive gears are awesome and are stronger than frpp gears. Cheaper as well. You can get them at www.mustangtuning.com
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
May 18, 2004
  • May 18, 2004
great, thanks!
*4.10 Gears
I think that would be a good idea. If you want, you can get a full bearing and seal kit for a little over 100 dollars and it will basically replace every nut, shim, gasket, and bearing in the rear end for no worries. Contact Randy Stinchcomb over at www.modulardepot.com under the Ford Parts department. He can get you the stuff you need and probably cheaper than most on the internet.
J
Joel's98GT
368
central OH
May 18, 2004
  • May 18, 2004
On Fluid:
Many people use 75w-90 in thier rearends if you use Royal purple you don't need to add friction modifier.
I think that Redline already has FM as well
IMO i like the 75w90 oil I use it in my daily driven rearend with 4.10's moser axles and 31-spline t-lok. do a search on MD and corral and you will see alot of people happy with it, and being a lighter oil it makes your driveline slightly more efficient.
Use FRPP gear it is the same part number as OEM (except there are 2 diff part numbers of 3.73) but for all other 8.8's the gears are identical to stock.
Wikkdgt
445
Cincinnati, OH
May 18, 2004
  • May 18, 2004
I have 50,000 miles on my 00, will I need to get the bearing and seal kit too?
smokin'Red35th
493
Las Vegas, NV
May 18, 2004
  • May 18, 2004
Bearings and Seals
Same question, i need to know more about this bearing and seal kit as well because if i need it i want to purchase it all at once. I have 79,000 miles on my 99.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
May 18, 2004
  • May 18, 2004
Maybe this will help. I have a 01 GT automatic that just now passed 20k miles and I will be using a full bearing and seal kit when I swap out my gears. No sense in doing a good job twice.
smokin'Red35th
493
Las Vegas, NV
May 18, 2004
#10
  • May 18, 2004
  • #10
Your right, what was i thinking???
J
Joel's98GT
368
central OH
May 18, 2004
#11
  • May 18, 2004
  • #11
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1165&prmenbr=361
you want the 1/2 of complete kit, you should be fine with either one. but I personally would get the complete.
H
HIGDON
241
Ft. Hood, TX
May 18, 2004
#12
  • May 18, 2004
  • #12
FRPP 4.10's from www.stangstore .com -I paid $150 shipped
IT took me about 2.5 hours to do the install, and most of that was just cleaning stuff. It's really not that difficult esspecially if you use the master housing dimension method that the factory uses plus you don't need a pinion depth guage. All you need is a good dial caliper or micrometer 1-2" and a dial and magnetic base. DIY and save a few bucks. Don't forget locktite and RTV.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
  • dan50
  • Jul 18, 2026
dan50
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Automatic to a 4-speed questions please
  • Woody3882
  • Jul 4, 2023
2K
1965 - 1973 Classic Mustangs -General/Talk- Mar 22, 2024
manicmechanic007
