4.10's, what are carrier bearings?
2000GTNY
31
Albany, NY
I having my 4.10's put in as I type this. The mechanic called me and said that the install kit I supplied didn't come with carrier bearings and he replaces these as a matter of procedure so he will be picking up these for me. He also had to get the left ABS sensor since it got damaged on the way out. The right one came out ok.
Anyway, what do the bearing do that he is replacing? I'm quite anxious to drive it tomorrow!
they are the bearing that go on your differential.
In the rear end there are two bearings on the carrier, two bearings at the pinion, and one on each axle. replacing them usually depends on milage. I replaced them all when I did my rear end just for piece of mind.
the abs rings are cast iron so I have heard they can break when removing. I got mine off okay which suprised me becaus I am always captain overkill on stuff like that so i figured I would break them both.
You guys both agree that he should be replacing them while its open then? It sounds logical to me and he is a very reputable mechanic in doing gear work. I'm glad I already own the XCal 2 so I can reprogram and hit the road!
how many miles are on the car? most poeple kind of just use milage as a guide as weather or not to replace bearings.
that being said if you milage is low most likely you could re-use them. In my case I was replacing the carrier so it was a no brainer to me. that way I did not have to pull the old bearings. get new bearing and have a easier job.
the bottom line here to me is the guy you chose to do the install thinks it is the way to go. if you try to make him do it your way it is probably going to piss him off and if there is a problem he could always pull that card so I would just do it.
:stupid: i agree with hognutz, depends on the mileage i really dont replace them unless the car car alot of mileage or is X amount of years
I have 55,000 miles now. I'm sure he is doing me a favor. I was just curious more than anything really. I thought I had picked up the proper install kit when I bought the gears. There were 3 to choose from. No big deal. I picked up the SVO girdle too. It should look sweet.
Thank for all of the input!
